Buffalo Machine Tools drill press
harrytbagger
After reading Red Leaders thread on his Retro Garage, I've got the bug for some older equipment. Came across this Buffalo Machine Tools drill press. Anyone have any info on these and what i should look for when I take a gander at it. Seller said that sometimes you have to start to spin the chuck by hand to get it started.
Any help would be appreciated from the tool gurus.
Here's the link.
http://quadcities.craigslist.org/tls/3184012423.html
Carla
MEMBER EMERITUS
Negative, I say again Negative.
That one is labelled 'Buffalo', but its an oriental joke machine with a deceptive label.
The shape of the castings alone is the obvious warning, like the rattles on a snake.
'Investigate before you invest'.......go to vintagemachinery.org, and look at the photos of old real Buffalo drill presses.
cheers
Carla
cheers
Carla
:+1:
Jim Johnstone
Brantford, Ontario
I have 3 Buffalo drill presses, and not the chinese buffalo things. The old originals won't be called "Buffalo Machine Tools" they will be "Buffalo Blower and Forge" or "Canadian Blower and Forge" for the ones built here in Ontario by the same company.
Jack Olsen
Los Angeles
The Buffalo 15 is a great drill press, and a really great looking piece of industrial design, too. I wanted this one, but missed out after the bidding went above $200.
Pretty much the same unit has been brought back into production. They aren't cheap -- but...
Instead I got a Rockwell from 1973. Which is also a good drill press, although it doesn't have as cool a look as the Buffalo.
As I got it:
After re-wiring and cleaning it up:
kabasor
Philippines
Nice, I've been searching the same kind here in our country (Philippines) but can't find one. We are flooded of China made here. Pretty hard to find decent drill press with a good deal such as the one you have..... Great find Sir Jack :beer:
PT Doc
As I got it:
Did you cut the post down or does it somehow go through the table? The latter would be great.
fireplug
Mine (Was $100)
Former Navy
Have you used yours much? Any opinion on it as a functional tool? I have been shopping for a DP and came across one of these (very beautiful too) but I don't want to get caught up in the romance of it and sacrifice usability.
I haven't been able to find any technical info on it, is yours model no. 5606?
zkling
They are good machines as long as you keep them in their work capacity, which is typically 3/8" and under in steel, will do 1/2" but a steady diet would be frowned upon.
