Ehhh, not really. Looks like a Baldor.Looks like a generic import sold under any number of names.
I'm not sure if it is factory or mod. Here are closer looks at "connection"s the extended shaft a factory thing or is an add-on mod? Is it threaded onto a shorter shaft or something? I can't say I've seen mismatched shaft lengths on a Baldor before, though I have seen them on much bigger buffers, Cincinnati, etc. If it were an add-on, then I'd probably guess a Baldor 7" grinder.
Thanks, looking at some photos of the 111 model, I think you may be correct (other than the long shaft on the right which may be a modification on mine). Mine is a greenish/gray while others I have seen are blue though.That label says it comes with a 20c 2p buffer. This link will bring the Customer Information Package, which may have parts list, etc. this will downliad a PDF.
That's definitely an add on shaft which is why it has the 2 flats on it at the inside end so you can get a wrench on it. I'd leave it on if you're wanting to use it for buffing. Those extensions are hard to find. Also each end has opposite threads, one right hand and the other left so the wheels and nuts don't come off from the torque.
