Buffing Steel
Mark in Indiana
Southern Indiana
For vises: Most of the time I use a 2.5" ScotchBrite disk attached to a mandrel, powered by a high speed air grinder.
For pocket knives: Sometimes I use Semi-Chrome and a buffing stick, or diamond grit mold polish.
During my working life, doing some mold repair: I've used >600 grit sand paper and polishing stones.
I also have my radial arm saw set up with a 10" buffing wheel & a 2.5" Scotchbrite pad to polish small metal details.
Hope this helps
Shiftless
East Bay SFO
Mark:
Clever use of a radial arm saw. I see them around here for almost free. Some were recalled and you can get a $100 back. If a guy has space, this is a great way to set up a polishing station.
As well as the Rolock discs, I use those 3 inch scotchbrite/sandpaper hybrid wheels a lot. For detail work, I have used a 3/4 inch diameter stainless steel wire wheel on a Dremel tool.
2oolhound
BC Canada
I use files or grinders to rough in then use emery cloth going from coarse to fine. Fine is 400 but I have lots of used strips that is more like 1000 grit and removes visible scratches. Then I use a coarse denim wheel with black compound then final a soft buff for the chrome look.
There is lots of good info on Caswell's site here:
http://www.caswellplating.com/buffman.htm#
