Building a 8x12 on a budget
me757
Looking for a 8x12 and decided to get a good one, just buildit. Has anyone build one on a budget and does anyone have advice.
Thanks
Catadj78
Alabama
I am starting a 12x16 in the morning.
http://www.garagejournal.com/forum/showthread.php?t=280078
Our budget was $1200
So far-
HD visit today was $699
1 36x80 metal door with deadbolt- $150
1 3x3 vinyl window $120
2x4s for wall framing
2x6s PT floor framing
8 sheets of 1/2" OSB for floor
I am going with metal exterior with wainscoting to match shop and metal roof.
Should be under $500 for metal by using prices I got on my shop materials.
Playwme
The Lucky Country Down Under
Use recycled materials.
I built the kids an elevated cubby house about that size. It's fully lined and insulated, metal roof, exposed Oregon beams and posts. All up I put about $1000 into it, and $550 of that was me purchasing a new Makita compound mitre saw.
Cyberbear
California
Years ago built a similar shed using redwood 4 x 4s as a base covered w/3/4" ply. Stud walls and T-1-11 exterior siding, with a 36" used exterior door. Went with three tab roof shingles for longer life than rolled roofing. lasted 25 years before I moved and left it behind. I once needed to relocate the shed for a larger garage build, I simply obtained peeler cores from the Home Depot and rolled the shed where I wanted it. No problems.
afbrian13
I built one for 600ish, but I did get my shingles free from a friend that had extra. I built the floor and walls like a house, except pressure treated for the base. It had to technically be moveable to not require a permit, so instead of poured concrete I used block stacked to make a level base. Tounge and groove plywood flooring sheets. T1-11 sheets on outside. I made the entire end a split door, open half for normal use, both doors to open the entire end wall.
Just design it for economy of materials-avoid leftovers, but you said 12x8, so thats easy.
Its held up 7 years so far,
Brian
dfiler2
NW Minnesota
Put a little money into the floor by using treated material for the joists and the floor, after that you can get pretty creative. A neighbor built a tool shed out of pallets and it turned out really nice. Here is a link to a few pics of some.
Colin Len
Long Beach CA
That's a really interesting idea to use pallets, I may consider that as I need to build some kind of shed pretty soon.
