effie_53
I have a 40' x 40' shop and a 40' x 48' barn, both pole buildings. The shop was there when I bought the property. I had the barn built lined up directly 8' apart from the shop as I always wanted / intended to build and enclose between the two buildings as if they were one large building. Originally, I just wanted to attach the second building but builders didn't want to because the roof pitches are 90 degrees apart. And they had concerns about getting it leakproof being the roofs are turned. I think that should be able to be managed even though all the snow and rain run-off from one side of the shop will come down on the center roof and split.
The shop has 14' sidewalls and the barn 12' high. I got two 36' trusses (think 4-12 pitch) from the local Menards this summer that they had on their clearance lot. The 36' is fine as I don't need to go the entire length and think it may be easier to tin in the seams between the old and new buildings. I don't need any more than a 7' ceiling height in the center. Just enough height for walk out doors on each end. There are existing walk doors on the sides on the two buildings. Planning to set the new construction in about the depth of the corner tin trim on one end and it would be about 3 3/4' shorter on the other end. That works as I buried the electrical line on that end that services the barn.
I think I'll attach the horizontal 2x6s to the original buildings 2x6s (after removing the tin on each existing building side) and then attach the 6x6 laminated posts to support the trusses. I'm building the 6x6s posts myself.
I'll want to have a concrete floor but don't know if I'll get that done this fall. When the builder put up the barn, he didn't get the floor height the same as the shop building. I haven't measured it but it looks to be at least an inch lower and could be as much as 2-3' lower. So I figured to have the floor height of the center building to be the same as the barn and step down from the shop.
I'm ooking for inputs on this project as I hope to do everything myself except maybe the concrete floor. I'm not opposed to doing that either but don't have any experience to speak of with concrete. I can post pictures later of the buildings..
