bad_idea
i have a quincy 325 in need of a rebuild. my question is what would be the problem with mounting it to a 30 gallon tank? i know this size pump is typically mounted to a 60 or 80 gallon tank. i'm thinking shorter time between cycles meaning the pump will run more often. also the air outlet from the tank will be warmer due to less time cooling in a smaller area. warmer air will be moist air. those are the only drawbacks i see, am i missing something?
i have limited space and i also have a 30 gallon tank on hand. kind of a two birds, one stone kinda thing.
