Building a new house.....
thejudges69
youngstown, ohio
So my wife and I have decided to build a new house. I'm acting as my own general contractor on the build, and before anyone knocks me on that, I tried to hire a builder. I called numerous builders, presented my idea and only heard back from 1, numerous follow up calls to several and still nothing. So for anyone that's followed my Peterbilt thread, if I can build a truck, I can build a house.
So, I'm listening to suggestions of anything I may have missed.
The house is essentially a barn home, it was mentioned in my last thread that it'd be a hard sale if need be. I've already spoke with my realtor and my house on 6 acres with my 40x100 heated truck garage next door will be an easy sale at a good profit, so I'm not concerned about that part.
So onto the house, it measures 36'x108'. The living space is 36'x84'. The house is a slab on grade with no basement. We designed the home ourselves off of a beginning draft I found, we made a good bit of changes and are happy with the design. The house started as a 5 bedroom, 2 bath house with a mud room, foyer, master suite, living room, kitchen and dining room. After we met with the architect, it was changed to a 3 bedroom, sewing room, office, master suite, dining room, kitchen and living room and a 2.5 bath.
The house has partial attic trusses in part of it, which is able to give us a 2nd floor play room for our boys with a walk area around the outer perimeter. Then the other part of the house will have a vaulted ceiling. I'll probably post some of the blueprints, but I need to crop my information out of them.
Down to the nitty gritty. The garage measures 24'x36'. We partitioned part of it into a mechanical room. The new septic will be installed, hopefully in front of the house. The house sits 212' off the road, so should be plenty of room for the septic out front.
For plumbing, I'm wanting to do a home run system with a manifold. We will need to add a circulating pump and line for the hot water, since the master suite is about 80' from the mechanical room. Everything else should be ok distance. All the pex under ground will be sleeved for maintenance. The sewage of course can't be sleeved. After that's all done, we will install the radiant heated floor, all 1/2" tubing for the heat and at this point 5-6 different zones and a propane boiler. I'd like to install extra leads in the dirt to the outside for any extras we may want to add later. And extra sleeves to the kitchen and master suite, just in case.
The foundation will be 8"x24" footers reinforced with rebar, 4-5 courses of block, the top blocks will be termite blocks, except every 4' will be core filled to secure walls to and a footer and block foundation under the front porch as well. I'm still working on how to secure my 6x6 posts to the front patio to support the porch roof. I'm also still working on the heat for the play area upstairs. I'm considering under the floor heat, the heating supplier is suggesting a register. I don't think I want that though
Walls will be 2x6 exterior construction, the interior walls are 2x4 walls. We chose a board and batten siding, with shakes in some areas.
The roof is a 8/12 pitch to allow for the 2nd floor play room and storage area. We've chose shingles for the main roof and we will be doing a 9" exposed fastener or possibly a standing seam roof for the front porch. All the windows are double hung except for the window over the kitchen sink, it will be 8'x4' folding window.
I think that's a good start to the thread, like I said I'll post some of the blueprints, but I need to get my address off them.
jblnut
In the Middle of MN
I'm also still working on the heat for the play area upstairs. I'm considering under the floor heat, the heating supplier is suggesting a register. I don't think I want that though.
I think that's a good start to the thread .....
A good start indeed !!! Sounds like it'll be the home my lovely Mrs doesn't want to build !! We had a 48x112 "shouse" drawn up and priced out and she got cold feet and decided she wanted a conventional home instead. Oh well.
We have a nice two story slab on grade plan drawn up now that we'll keep tweaking until we decide to build and we will have in floor heat as well on the main level. Upstairs we'll have forced air as we'll have a furnace/blower anyway for the A/C. How will you be handling the A/C ? Our HVAC guy told us it made sense to heat upstairs with the forced air as we'll have the furnace anyway. A couple mini-splits would also get it done but more likely at a higher cost. Plus, the furnace gives up a backup source of heat as we'd likely put in an electric boiler.
Sounds like it's going to be a great build once it gets going !! I'd love to see plans when you get your info scrubbed off them.
T
thejudges69
youngstown, ohio
I am waiting on my HVAC guy to get back with me. I originally wanted the AC overhead up high, so it would blow cold air down. He's saying that there is a point where your out of the "safe zone" for ac, I think what he's referring to, is that it's actually working harder than one would think. So I don't have that answer yet. I will update when I do.
My wife and I decided it was time. We have 2 boys 6&2 and one plays hockey and the other I think will as well. Our now home is 1200 sq ft and just way to small, we weighed all the options to upgrade it and put additions on and decided it wasn't a smart financial move. It will actually be donated to the local fire company and burned when we move into the new house. It wasn't what we wanted, but we really have no other option at this point. So it will at least get us a tax write off.
