eyesoreracing
I desperately need a shed to get the stuff that isn't car tools out of my itty bitty garage. Bikes, lawn tools, house tools, all that stuff has to go somewhere else!
At work, we get parts air shipped from Japan all the time, and they come in these clever corrugated steel containers.
These things are amazingly lightweight, very strong, break down into flat panels without any tools, and get thrown away all the time. The temptation should be obvious..
Each panel is very thin corrugated steel spot welded to a simple frame. If you lay the sides down next to the floor and stand them up in just the right way, the bottom of the side panel hooks to the floor with no tools. Two adjacent sides interlock with each other at the corners, and are held together with these little brackets that just slip into slots in each side's steel frame.
Over a couple of days, I dragged home four of these containers, in two different sizes, on the roof rack of my Mazda3 (told you they were light...) and finally started assembling them in the backyard this weekend.
Using three sides and a bottom from one of the large containers (roughly 7' by 4'), and one side from a smaller container, I made this handy shape:
The second level of steel walls is just held to the lower wall with self-drilling sheet metal screws.
As you can see, this looks like it will make a decent shed with a big door on it.
I love the bare metal look, but sadly these are mild steel and start rusting pretty quickly, so I decided to paint the shed to match the house. Since I'm a cheap *******, I only bought one gallon of house-colored paint. That should be enough to paint the parts of the exterior you'll actually see. The rest I painted with a bunch of old nasty leftover paint from parts of the house we don't like. We'll be repainting the mauve bathroom anyway, and the pink trim on the house just has to go. That spare paint goes on the bottom of the shed and the side that faces the neighbor's fence.
So far the shed has cost me about $27 for that gallon of paint. I added another $6 buying 8 cinderblocks. I used my iPhone and a piece of wood (and a friend with a shovel) to make the blocks level.
The shed will sit on a mild slope, that's why the farthest block is sunk so far in the ground. The two staggered ones are dodging a big root.
I was going to take the shed apart, move the floor over to the cinderblocks, and reassemble, but my shovel-wielding friend thought we could just pick it up fully assembled. Turns out he was right. We put two 2x4s under it, lifted with our knees, and easily carried the box to its new "foundation".
You'll notice the third story has some ridiculous looking ears sticking off it. I needed three big containers worth of panels to do this right, but only had two big and two small. The ears are the long sides of the small containers.
A few minutes with a cutoff wheel and some more self-tapping screws and I had the ears trimmed down:
Yes, that is blood. Metal gets sharp...
I'm hoping to have a roof on it tomorrow. I had to spend about $100 on supplies for the roof (some 2x4s and some of that clear corrugated fiberglass junk)
After that, I'm trying to turn the floor of one of the small containers into a sliding door. Not quite sure how that's gonna work yet...
Not much work as we were spraying the house with a spray rig. It finished off the rest of the paint perfectly!
