Building a shop crane into the foundation.
dreamingmuscle
Tryon Oklahoma
Like the title says want to put a custom home built shop crane in my son's new shop.
Been watching Paul Cox on YouTube. Fabrats is his channel, funny guy builds mostly rock crawler stuff, and making repairs to family vehicles. Nothing he does is pretty cool but not pretty LOL.
Any way when he built his shop he put a two ton truck axle into the floor. He built a crane on top of the hub and uses a semi cage brake to hold it in place. Works like a charm.
Well two ton truck axles are in short supply around here. So I was thinking of using a Trailer axle. 3500 pound axles are plentiful and cheap but a Little too small I think. Any thing above 3500 pounds almost doubles the price. Mobil home axles are plentiful but not so cheap also.
So any suggestions?
Video of said shop crane here. It's only a 9 minute vid and the crane is at about 1:45
LopezBart
Lopez Island, WA
Historically, I think most shop cranes were jib cranes, with the building walls providing the horizontal strength. Now that shops no longer have dirt floors, self-supporting cranes are much easier. Here's an old thread on the subject:
D
dreamingmuscle
Tryon Oklahoma
That's a nice build but very limited in range and height. I think it could have been built with a little more reach though.
LopezBart
Lopez Island, WA
Whatever you end up doing, get someone with a solid engineering background to validate the design. A nice fat factor safety factor is a good idea. If I get a crane, I'll go with a portable gantry since it can go with me on the equipment trailer. If I get a 10' wide unit, it will span the trailer.
rancherbill
Foothills County, Alberta, Canada
Take the advice in this thread and get professional help. Don't' take advice from a guy that just has one. It is not rated, or properly designed, or a hundred other things. It, at this point, cannot be described as 'works great", it can described as "works so far."
zkdiesel
chicagoland cornfields
Take the advice in this thread and get professional help. Don't' take advice from a guy that just has one. It is not rated, or properly designed, or a hundred other things. It at this point cannot be described as 'works great", is described as "works so far."
Only thing I liked in section of video I watched was the air can brake but there’s many ways to do that
Hakeem
Chicago
Forgive me if I underestimate your capabilities but Rigging up a cantilevered crane from an old truck axle sounds insanely dangerous. A two-post hoist type of thing would be safer but I don’t think this is the kind of thing you want to be making yourself. The risk:benefit ratio is totally unfavorable
D
dreamingmuscle
Tryon Oklahoma
Why? A two ton axle is designed to hold a lot more then let's say a engine. Axles are are also designed for impact loads stresses too.
This will just be lifting static loads of what 400-600 pounds or so. Not counting the jib crane materials weight.
He's not going to building tanks here.
mike93lx
Richmond, VA
I am confused on what an axle has to do with this, but I am also confused on how the loads imparted on a jib crane are comparable to what an axle is designed for.
Very few people are going to encourage someone to cobble together a hoisting device
racecougar
Missouri
The video in the OP shows/mentions a 2-ton truck axle embedded in the floor as the base of a jib crane. The OP was looking to do the same with a 3500lb trailer axle.
loganb
Omaha, NE
Used Jib cranes do seem to be plenty plentiful. So might as well not reinvent the wheel here.
Yes. They're cheap, biggest challenge is going to be moving them. You can often get them at factory/company close out auctions for pennies a pound, but they have to be removed by an insured rigger. They'll normally have a rigging contact on the auction you can call to get a price quote to take down and load on a trailer.
Once you get it home, as ZK mentions the foundation is critical so that part needs done right. Depth, soil prep, reinforcement. It's not necessarily "hard" but the forces on a jib crane are often under estimated
A cheaper option for a new build can also be a single axis trolley crane. A properly sized steel beam, supported on both ends with a steel post on the proper foundation may be easier to put in, but can be less useful cause it only goes in 1 direction.
Don't think I have any pictures on this computer of the foundation for this crane in the farm shop, but it's big. It was placed there so we could use it to swing over the welding/machining area as well as 2 bays where equipment would often be
wssix99
Chicago, IL
Just go buy a used job crane. Cheap to buy!
Foundation is key.
I have 4 jibs. All have proper foundations.
Your reach makes it scary for the forces applied
What he has is very sketchy
Indeed. The guy in the video is benefiting from some dome luck in his placement of his "foundation". A proper foundation is isolated from the slab, which keeps things from cracking all to hell. The guy in the video placed the crane at the corner of a controlled section and got lucky that things didn't crack up.
... and the rig in the video will never be able to withstand the forces that can be put on the end of that arm. That a contraption I won't stand under or near.
dura eagle
That photo looks very familiar 😎 your dads buddy form western Kansas now in Missouri here. 😁
PoorUB
Fargo, ND
I might be wrong, but I would assume he has the top of the column for that crane supported from the structure of the building. The bending load on the bearing in the floor on a jib crane is crazy without a top support.
I could do the math, but he is about ten feet up, and another 8-10 feet over with the arm. Hang 500 pounds at the end of the arm and the bending load at the floor is huge.
I worked at a machine shop and we had two 500 pound jib cranes that we built. The upper end on both was tied into the building.
LopezBart
Lopez Island, WA
If the building is designed with adequate shear strength in the walls and they're properly fastened to the foundation against uplift, this works well, since the size of the wall panels can reduce the reaction loads to reasonable levels. The antique machine shops I've seen used cranes like this.
For me, moving heavy things is rare enough that I'm willing to spend time rigging temporary lifting mechanisms. When I pulled the boiler out of our smaller steamboat, I didn't have a good lifting point high enough, so I bought some long 4x4s, and fashioned a tripod that would straddle our boat; I then lifted the boiler, and slid the boat out from under.
speed bump
Butte Montana
You don't want the rotation mechanism at the bottom.
If you don't want a big base then you will end up putting a bunch of concrete in for a base. I was visiting with one of our contractors and they put in a piece of 16" sch 30 42 inches in the ground and poured a 4x4 block of concrete around it then added stiffeners at the top of the concrete. That for them will handle a 10 ft swing at ~3000 lbs
My quick and dirty idea for a while has been a piece of 6-8 inch pipe with a Super duty unit bearing in the top and some cheap roller bearings for the lower support. Use a 6-7ish ft piece of S6 for the rail. Then at the base go roughly 30x30 of half inch plate the base with a bunch of stiffeners. Set on 6" of concrete with epoxy anchors that will do most of whatever the home gamer will do with a jib crane at 8 ft. I haven't ran the numbers yet so certain parts of that may change when I decide it's time to build one but that's in the ball park of what an existing commercial unit looks like.
zkdiesel
But used commercial units can be bought so cheap or free it’s not worth it
backupbeeper
Is just get a used overhead crane
Or a portable one
I see em for sale all the time .
speed bump
Butte Montana
Depends on where you are. Here they rarely come up for sale and they are priced in accordance. If that was the case I would have a jib crane off the side of my driveway already. For building one I have access to a plasma table and a scrap bin that occasionally has a salvageable piece of pipe that is the right size so other than design and assembly I can build one pretty cheap.
