Hey guys,
I ended up making a box from wood in the end. After about 30-40 minutes the thermo reads 210-215*F so I am pretty sure I should be able to bend properly. Since I have never done this before I do have a few questions:
How should the grain be oriented?
I am looking to make snowshoes which calls for white ash, I am wondering what thickness range I can bend in.
How long would you recommend I leave the piece in the box for before attempting to bend?
I understand that some of the answers depend on specifics, and I have read some of this info on the net elsewhere. I am just looking to get a solid idea from GJers since I know we are a capable bunch.
Thanks!
PS does anyone know where I could find white ash staves? Online or local???
I'll take a stab at this,
Wood can be bent in any direction, for a snowshoe it needs bent both with and perpendicular to the grain.
The bigger issue is making sure the grain does not run out, because it will be far more prone to breaking if it runs out.
Pick the straightest vertical grain timber you can find.
The easiest way to insure the grain does not run out, is to split it,then plane the split side and then lay out the cuts from that edge.
You can bend any thickness you want.
Wooden ships had massive bent frames in them, for example.
I'll post a pic of a full 1"x2"white oak stem and a 1"x1-1/2" 160 degree yellow cedar breasthook.
A good starting point for steaming is 15 minutes per 1/4" thickness
The time needs adjusted to the wood being used and moisture content.
Myself, I like to soak the wood in water for a few days before I steam or boil it to bend it, because I don't have access to green wood
Hope this helps
Royce
