building foundations
59ragtop
hi all has any one got any pics of info on buikding the footing and floor so i can get some idea of what to do i need to make a 4" floor with 1ft wall all the way around except opening for doors i also need to fit securing bolts to fix the wooden frame. thank you
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Look in the Gallery under the builds. Almost everyone that has posted their garage build from the start has shown pics of the footings and stem walls. Not knowing where you are at would determine the type of footings, but most go to the frost depth, pour a 12" x 12" footer and lay the block on top or have a solid wall poured to the height needed. Then start building on top of that.
