BuickFarmer
Having not been able to find a dealer anywhere close (200 mile radius of Athens GA) I am considering building my own out of a combination of 3 layers of treated and untreated 2x6's. I have found a local supplier for the .60 treated pine 2x6's. I plan to build a jig to keep them all straight and butted up to each other as they are being nailed. I will flip the crowns of every other one and walk them down straight as I shoot two staggered rows of galvanized ring shank nails every 18 inches. My currently planned layout plan for the 16' posts is, as you are looking at the post from the side and left (ground end) to right, the bottom layer would be 6' PTP and 10' SPF. The middle layer would be 8' PTP and 8' SPF. The top layer would be 4' PTP and 12' SPF. (I plan to bury my posts 42") As the poles will end up being enclosed in the wall and cosmetics is not an issue, I will use Simpson Strong Ties on the two outer joints. I do not plan to use glue. The lengths of the SPF will increase as necessary for post lengths up to the max that I will need, which is 22 ft.
I would be interested to hear from members who might have laminated poles from Menards or Graber Post Buildings and what the lay out for a standard store bought laminated 16' post would be.
Thoughts, opinions???
