bthucknall
- Joined
- Apr 23, 2016
- Messages
- 14
So like many other people after looking at all the used tool boxes out there I felt like I could build one myself for less than what I can get even a used one for. I’m a mechanic and have been working out of a stainless steel 4l”x18”x64” box for ten years now. It’s made by knight, i believe it was sold by sam’s or costco’s or someplace but it has never given me any trouble other than some sticky ball bearing slides that I just had to clean. I think it was less than 2 grand new, but I bought it with my first tool set used so I've been happy with it. Here is a link to my current box.
( http://www.garage-toys.com/noname21.html )
The problem is that since i’ve been working for myself it hasn’t been close to big enough for just my hand tools, much less all my diagnostic tools. So i figured I’d biuld a box that was the largest I’d want without it getting difficult to move around the shop, and also have it built pretty modular so that each peice could be lifted by two strong guys while loaded down with tools. I knew I wanted a work surface, and eventually a riser with top locker and side lockers for my tools that are already in cases.
The largest height i could have and the work surface still be usable was about 42 inches. With 6 inch castors i figured that two stacking boxs of 18 inches each was going to make it easy to pick up and move when I wanted to. I wanted all the drawers to be a full 48 inches wide and close to 24 inches deep. After sitting down and making a bunch of drawings, looking at what materials I could get, necessary clearances for the ball bearing slides, I came up with a frame that was exactly 18 inches tall, 24 inches deep and 51 ⅛ wide. Two of these set on top of each other would make my main tool chest. I would put 48 inch wide drawers that were 23 ¾ inch deep in them. Leaving ⅛ separation between drawers, I decided that one box would have an 8”, a 5”, and a 2 ½” tall drawer in it. The top box would have three 2 ¾” drawers, and two 3 ½” drawers. This would give me a box with something close to 1.5 times the volume and area as my current box.
After going to a local metal supply i decided to use 14 ga 1x1 steel tubing for the frame. I built it and then felt I needed gussets so I cut a bunch of gussets out of ⅛” 3 inch wide flat bar and installed them everywhere I could except the top, because I didnt have a plan for a work surface yet and didn’t know how I was going to reinforce it. I ended up putting two more lengths of the same tubing across the top and two ¾” 16 ga tubes in the back to reinforce them. I think im just gonna use hardwood flooring for a work surface, its alot cheaper than paying for a butcher block or having someone make me a stainless top.
Ive got a local fabrication shop making the drawers out of 16ga galvanized, with a ½ inch lip turned in on all edges except the front, which has a 1 inch lip turned out for a drawer pull. I couldn’t afford a brake so they're gonna brake them and I'll weld them up.
Ive got Accuride C 3832-C24SCP drawer slides for it, which are the heaviest rated slides I could get without breaking my wallet. They’re rated at 100 pound each, and are similar in size to what I found in a snap on box. Accuride at one point was making snap on’s slides, so I figured they were what I wanted to use.
I haven’t decided on how to make framing for attaching the drawer slides(i’m thinking more of that ¾ tube), or what I will skin the frame in(considering ¼ inch oak plywood, putting good marine varnish over stain), and face the drawers with(considering ¼ inch solid oak finished the same way). If anyone has any advice or experience with any part of this i’d really like to hear it, the only other things i’ve welded and fabricated is a trailer enclosure and a welding cart. With everything included it looks like I’ll have less than 1500 into this box, and that it will have more room than a snapon krl 52” roll cab.
