69Cat
I'm going to put this out here and see if there are some other solutions to consider.
I need to span a 26' wide space (50' long) above my main shop to put in a 2nd floor for storage of the usual junk that collects through the years. Would estimate a 40 lb/sq ft loading at the maximum, keep in mind the heavy stuff would be around the edges and certainly not in the middle of the 26' span.
Due to screw up in the building I got a 12:1 roof pitch instead of 12:2 pitch so I am left with a little less headroom than planned and so I want to have a floor with a depth of 10 inches or so. Engineered wood trusses are 18" or 24" high for what I need and I have to run 8" joists on top of that too so I run out of room fast.
Thinking of using W8x28 Ibeams to span the 26' spaced every 12' and then put 2x8s into the webbing to bridge the 12' between I-beams.
Does anyone know how to calculate the deflection on an I-beam with a given span?
For securing the joists to the I-beam I can think of two options:
1. Angle brackets welded into the I-beam web and bolting or nailing the joists to the bracket (as per attached sketch)
2. Make a wooden header to fit inside the I-beam web and bolt it to the I-beam so that I can nail traditional joist hangers to wooden header.
Anyone try and do anything like this or have other ideas to provide a 26' clear span and minimum depth of floor?
Ken
Ken
