Im about to build a sturdy 8' x 30" work bench of 2x4's & plywood, was planning on attaching it to the wall studs, with some vertical support from the stem wall to bottom of frame, and double 2x4 legs on the front side. The bench will go where those 2 home depot rack shelves are now.
My walls are pegboard screwed right to the wall studs, with insulation between the studs.
Do you think id run into any problem bolting the ledger board on top of the pegboard? Like the pegboard eventually coming off the walls from hammering on the bench? I was thinking about cutting the pegboard at the height where top of bench would be, but it would be a bit of a PIA with a utility knife, i think my circular saw might make a mess with the insulation behind it.
I could also run a 2x4 horizontally across the wall higher up the to keep the pegboard from coming off.
https://scontent-ort2-2.**.fbcdn.net/v/t1.0-9/42821476_272824796894955_24904994931081216_o.jpg?_nc_cat=103&_nc_ht=scontent-ort2-2.**&oh=219ba18706eca7cdf167e0b82b1ca652&oe=5C7F602F
