Built a cart for my new weld positioner
pb57
Sioux City Iowa
Built a cart for my new MBC Weld Positioner. (made in USA) I was always going to build my own positioner but didn't have time, then I got a large job that required one. So I built the cart and painted it up with some Ford engine blue and clear coat. Nothing fancy but a fun and useful project. Now I can get to work on the real project. thanks Paul
zkling
Very nice setup with the spin loc chuck and all. Can you share any details on the components you are using it for? I was looking at an R2 a few years ago, but ended up making a roto-star style copy as I had an optional job that would require a 3" through.
P
pb57
Sioux City Iowa
Thanks Zkling, the parts are nothing special. Just a bunch of brackets for hog confinement waterers. I also do a lot of work for farmers in my area and build up a lot of shafts that are worn, then turn down to size on the lather. Paul
zkling
How automated is your setup?. Are you building up the worn shafts with wire or flame spraying?
P
pb57
Sioux City Iowa
Zkling im not familiar with flame spraying. I use wire. Would flame be a better choice? I am always willing to learn new methods.
P
pb57
Sioux City Iowa
Yep, just built it this summer. I just retired and was tired of painting for years in less than ideal conditions.
zkling
Depends on the application. It is becoming a dated process outside of robotic booths. Typically reserved for when you need a hard surface or minimal heat input into the item. Some folks are doing it in their small shop for special applications. For a while I worked in the aerospace repair industry where it is quite common.
Just curious what you were doing as shaft buildup is one of those that can kinda appear to be a black art.
dkmc
NYS--Upstate in the corn fields
Looks great. When I built my DIY positioner, I welded on a stub shaft that allows it to just plug into my engine stand. Being able to very simply rotate radially from vertical to horizontal helps with some setups. I want to get one of those quick acting chucks for mine, they work slick.
P
pb57
Sioux City Iowa
The quick acting chucks are great. I really like the MBC and after talking to others that own it they feel it is underrated as far as the weight limits. All the parts are also available through Grangers if there are any problems. Unlike the Chinese variations out there. thanks for the comments guys. Paul
