Bunk's Drill Press Table
Bunk
Alexandria, VA
Time to share a new drill press setup I put together as I am building out my basement workshop. While I wait for my main light fixtures to arrive, I took a little detour and decided to create this drill press table and stand setup.
View media item 8060
The Stand-
The stand is the HF 7 drawer side cabinet. I fabbed up some leveling feet and a steel reinforcing frame for the bottom as it isn’t really designed to stand on its bottom. I topped it with a 3/4” MDF to stiffen up the top and minimize flexing.
The Table-
I did a bunch of research, collected a ton of ideas from everywhere I could find a design, sketched out a basic design and started work. In hindsight, there are a few details that I would definitely have changed had I planned the design a little more carefully, but they aren’t anything that I can’t work around.
View media item 8061
The top is ~ 24×18. The table surface is 3/16 Hardboard that has many layers of Johnsons paste wax on it. I didn’t think I’d like it, but it really gives a nice working surface. Underneath is 2 layers of 3/4” MDF. All three are glued together. I discovered a little too late that I really wasn’t setup with enough clamps for this glue up (hey I am just starting out), which prompted a minor clamp buying frenzy the next weekend. I trimmed out the edges with some 1/4 maple strips – glued, but again due to a scarcity of clamps I had to resort to some finish nails (do differently next time item#1).
I routed a 4” recess for the 1/2” MDF sacrificial surface under the quill. I wasn’t really 100% happy with how it came out. I kinda rushed putting together the router jig and I left the whole “bottom” if you will, instead of just leaving a ledge for it to sit on. It works for now, but I may try to clean it up later.
The two fence/hold down clamp t-tracks are placed a little too close to the outside edge, in that I can’t rotate them to be parallel with the fence as the tails will hang off the sides. Again no biggie, they still work great.
View media item 8063
View media item 8064I liked the idea of an aluminum fence. I added a strip of PE cutting board material. Made the stop block out of the same angle the fence is made from, but with one face shortened up a tad. I love the cam locks on the backside.
View media item 8065The table attaches to the drill press with some carriage bolts. I had originally planned for 3, but I neglected to account for the metal table support arm in the back so, there isn’t enough room for the same knobs I used up front. I may or may not try and find another knob that’ll work, as the two up front seem to work great, and I hate to spoil the quick off and on possible right now by adding a nut and washer to the back. I think it would have been better to bury the carriage bolt underneath the top layer of hardboard rather than having the countersinks visible, but maybe not…I don’t know.
In order maximize my table surface, I had to bevel the back bottom edge for the height adjusting crank.
All in all I am quite pleased with the table, its been a great addition.
There'll be more on the rest of the shop as the build progresses.
Bunk
Jswain
Calgary, AB
That is awesome, I just finished up mine but now seeing yours, mine may not be finished enough...great work!:beer:
Bunk
Alexandria, VA
Thanks guys, much appreciated. :thumbup:
I can't take credit for any singular aspect of the design, only putting them all together from a whole bunch of different designs I found when figuring out how I wanted this thing to look.
I've been quite happy with how it functions, and don't really feel like I'd change anything if redone - other than the clearance for the DP height crank handle.
John11
Awesome setup, i will have to borrowm some great ideas, thanks for sharing.
Reno4u2
Las Vegas, NV
Bunk...thanks for posting! Exactly what I am looking for. Realize this is an old thread but are you still using it? Any upgrades or advice? Thanks again!!
ps...more interested in the HF box mods...
Bunk
Alexandria, VA
Hey Reno, thanks. I AM still using it, almost exactly as it's shown here.
What would I do differently? The height adjustment handle to rear edge of table relationship. It's just too close for my tastes. I've seen some guys that have extended the handle out by adding a longer shaft with joints.
But you've asked about the HF cabinet mods...
The base is a simple combination of 1.5" x .125" angle and 1"x2"x.125" rectangular tube. There are four threaded adjustable feet to get the thing leveled. When I built this I didn't have the equipment to weld it together, so it's a bolt together design. The two angle pieces span the depth of the cabinet on the underside and bolt to the bottom edge of the cabinet. The two rectangular pieces span the width and bolt to the angles. Make sense? I could try and take some more detailed pictures of that arrangement if you need.
I told myself that someday I'd take it apart, weld it (base) together and then paint the whole thing a nice color - not a huge fan of the matte HF red. But that hasn't happened yet.
Overall it's been a great setup for me. Plenty rigid and heavy with out any hint of tippiness.
Reno4u2
Las Vegas, NV
Thanks Bunk! A couple of pics if you have time would be great. It looks like the rectangular pieces that span the width are extended a couple of inches on each side? Would definitely aid in stability...kinda like outriggers.
ishiboo
Oshkosh, WI
Great setup... I'm considering doing something similar with my bench top drill press, if I don't get rid of it. I recently bought a larger floor-mount and wonder from time to time if the bench top couldn't go away.
Bunk
Alexandria, VA
Alright, here is some more detail of how I mounted the support structure underneath and attached the leveling feet.
View media item 81001
View media item 80999
Pardon my cobwebs
View media item 81000The bolt that attached the cross beam to the angles only goes through the top of the box section. There is a hole on the bottom surface that gave clearance for a socket to tighten the bolt.
Seem clear enough? Thanks for the compliments, they are much appreciated.
Tripp2012
NC
I like the set up. I have the Harbor drill press table mounted on my DP. The tall fence can get in the way though using a short bit and drilling close to the fence. The chuck will hit the top of the fence while drilling. I plane to shorten mine and do something similar to the Woodpeckers set up.
John11
Thanks for sharing the pics of the base upgrades. I have a cabinet like this I am looking to convert to a drill press table as well.
