Buried Axe Blade
rakane
Warren, Oregon
I found this on my property. Will I ruin the temper if I use my burn pile to remove the wood (or a torch)?
The alternative just takes longer.
I'm saving it for reuse.3138182c2737f0a3bc270e6be149b309.jpg6071f7cd1860f5f5e077b0be6ae303ac.jpg
Meanwhile is a 30' Grady White.
cowboy73
southern Indiana
I wouldn't try to burn out the old handle. there doesn't look to be a whole lot left of it. I would drill and chisel the old handle out.
Zexx
GA
I would beat it out with an old screwdriver or a punch from the broken end.. shouldnt take more than a minute or 2.
5ktq
thirding the punch from broken end
except probably use a piece of flat instead of a punch.
dogdog
You can always just torch it at that specific area to char the wood pieces enough to loosen and soak it in water. ... it won't affect the temper of the edges... you'll have to get it really hot to affect the temper.
Stuart in MN
Minneapolis
It will take less than five minutes to drive the wood out with a punch and hammer, no need to mess around with a fire.
woody 73
The Great State Up North
No need for any heat, like the others have said use a chisel and punch and knock out the old wood, i do it all the time very easy not rocket science. Buy a new handle and you will be back in business in no time.
Legion Prime
Leelenau County MI
That's an awesome find! You might not even need to drill it. If you can get a screw into the wedge and pull that out you may just be able to hammer it out, easy.
JR 42
Sunny Seattle
Yes you will, cripes, don't heat hardened steel if you don't have to. You can knock that out with an old bolt and a concrete floor, don't burn it out.
CR888
Its a real nice axe bit, rehung after a little clean up and fresh edge would make beautiful axe. Please don't burn it.
Indexmill
Central NC
Don't burn it out. Hammer it out. Don't burn it out. Hammer it out. Don't burn it out. Hammer it out. Don't burn it out. Hammer it out. Don't burn it out. Hammer it out. Don't burn it out. Hammer it out. Don't burn it out. Hammer it out. Don't burn it out. Hammer it out. Don't burn it out. Hammer it out. Don't burn it out. Hammer it out. Don't burn it out. Hammer it out. Don't burn it out. Hammer it out. Don't burn it out. Hammer it out. Don't burn it out. Hammer it out. Don't burn it out. Hammer it out. Don't burn it out. Hammer it out. Don't burn it out. Hammer it out. Don't burn it out. Hammer it out. Don't burn it out. Hammer it out. Don't burn it out. Hammer it out. Don't burn it out. Hammer it out. Don't burn it out. Hammer it out. Don't burn it out. Hammer it out. Don't burn it out. Hammer it out. Don't burn it out. Hammer it out. Don't burn it out. Hammer it out. Don't burn it out. Hammer it out. Don't burn it out. Hammer it out. Don't burn it out. Hammer it out. Don't burn it out. Hammer it out. Don't burn it out. Hammer it out. Don't burn it out. Hammer it out.
Got it?
bwringer
Indianapolis
You know what to so, I guess.
I'd install a new handle and sharpen it and use it, but I wouldn't polish it or anything; that patina is just cool as hell.
rick carpenter
Huntsville, East Texas
Drill it and press it out. Perfect use for those old dull drill bits you haven't thrown away yet. The heels don't look worn on one side so it looks like it didn't see much use before disappearing. But the blade bevel profiles are just not right, they are way too convex. You should re-grind and sharpen both with one bevel 'fatter' than the other for dirty work around roots/etc and the other 'skinnier' for chopping and limbing. Use gloves when you sharpen it.
Show pics when done please.
R
rakane
Warren, Oregon
Thanks for the replies.
The only mark is a M on one side.
I found a large single blade axe head but it has a crack right down the middle. It would fly off a new handle.
I found a smaller 3 tine pitchfork head. I'm going to restore that for use also.
