Burnishing after Densifier?
Samh
Canton GA
So just finished applying Euco DiamondHard sealer/densifier to my floor. Does anyone burnish it afterwards? Is there any benefit to it? Should you/do you have to do other steps aside from burnishing?
Samh
Canton GA
Nevermind, after it dried, it doesn't even look like I did anything. There is a real fine dust on it now though.
Shea
California
Euco Diamond Hard is a type of sodium silicate densifier. It requires more work and attention to scrub in and rinse properly compared to the lithium silicate densifers. The fine white dust is what results when it is either overapplied and/or not rinsed well and kept wet for 30 minutes after application. It can be removed via heavy scrubbing.
Samh
Canton GA
I applied by pouring on the floor and using a t-bar floor applicator. I kept it wet for at least 30 minutes while applying. I did not rinse, as the instructions didn't say to rinse, only apply water if it started to gel. I attached images of what it looked like when I finished application, and 48 hours later. I also don't think I would classify what I did as working it in, vs just covering the floor.
Shea
California
That's correct about keeping it wet. Rinse was a poor choice of words.
That doesn't look bad at all from the pic. Just as an FYI for future applications, the instructions state the following; "With soft bristle hand brooms or brushes on an auto-scrubber, work the EUCO DIAMOND HARD around the area to be treated and into the surface."
This is most likely why you have a bit of residue on the surface. The sodium silicate molecules are larger than lithium silicate molecules and require a bit of scrubbing to work into the concrete. Keeping it wet is important because the sodium silicate raises the pH in the concrete and can push salts and other minerals to the surface.
Samh
Canton GA
I think because I was expecting a sealed type surface like you see at box stores is part of it. I went ahead and calledEuclid Chemical to ask, and they said it was normal. They said I can burnish it now, and it will get more of a sealed looking finish. Seems weird though, as it just looks like regular concrete, so I can't imagine it would make a difference.
So, for the other section of floor, to avoid the yellowish powder, work it in better?
Shea
California
That's correct. Just follow the application instructions all the way through and you should get much less of the yellowish residue. Burnishing a sodium densifier is not going to provide a big change though. You will definitely notice a difference between where you burnished and where you did not, but it's not going to bring out a shine if that is what you are looking for.
If you want more of a shine, then I would recommend scrubbing the surface well first with a floor maintainer using black cleaning pads to remove most of the residue. Densifiers take a full week to react with the minerals in the concrete, so you will want to wait at least that long before scrubbing. You can then apply a stain guard and then burnish that. They are typically used on polished concrete to keep the shine and help to protect it. We have an example of such a project below.
Samh
Canton GA
Luckily, the residue comes up fairly easily with a push broom. The link to the HD40 concrete guard looks like the finish I would like on mine.
