Busted Craftsman Ratcheting Combo Wrench
TheClaw
Chicagoland
I've got a set of these Craftsman ratcheting combo wrenches. The 8mm decided not to ratchet anymore. The center piece spins fine, except in both ways.
Yeah, yeah, lifetime warranty. Except you can only replace ONE wrench and they don't sell them individually. At least at the ACE Store I checked.
If you know of a way to get a replacement, please share. Otherwise I'm looking for info on how to fix it? Yeah, another long shot.
Wrench97
Southeastern Pa
What do you mean you can replace only one wrench?
Did Ace have a suggestion?
If not they should be breaking open a set to replace the defect.
Is there a Lowes near you?
4xdog
Santa Fe, NM
I have four sets of those -- two mm versions and two inch versions. I use 'em all the time!
The first set I got was marked, like yours, "Craftsman". When the Sears service center/outlet not far from me living in Saint Louis at the time had the same wrenches (now marked "Craftsman Industrial" I bought three more sets for something like $20each. One of my smarter moves...
They're marked $69.99 here, but they were considerably cheaper at the outlet center display.
Perhaps you could try going directly to SBD and seeing if they'd warranty it with the corresponding Craftsman V-series wrench (a FACOM original, well-made in Taiwan)? I have a set of these too, and they're quite nice -- boatloads cheaper than the FACOM-branded version.
Does Proto make a similar version? If so, it's probably still made in USA.
designer485
Orange County, CA
Go online and put in a request for warranty. I recently requested warranty on a single t20 torx T handle (that was bought about 20 years go). I wanted to see what they said. So my surprise, they ended sending me a full set replacement. The folks on the other end of the customer service email were very accommodating. Send it in and see what they say.
Send in a photo and estimate the purchase date if you don't know exactly. When one section asked for a receipt, I uploaded a photo of the "Made in USA" on the back as proof of the lifetime warranty.
neophyte
Pennsylvannia
Is/was this one of the Danaher/Armstrong/USA Gearwench made wrenches?
Also, if you have some marvel mystery oil, maybe dip the wrench in case something inside is just stuck.
drmarkr
Tucson
Love Ace, but their Craftsman warranty process is a PITA Here in Tucson, even Ace employees send you to Lowes, which is utterly simple.
In your case they would pull an 8 out of the set and be done with it.
Shitbox
This may or may not help but, I had a couple Gearwrench reversible combos that would lock up and not ratchet or they’d reverse on their own, shot a few squirts of Kroil into the gap of the ratchet head, let it soak for a day and oiled them with some gun oil, worked them for a few minutes and they freed up and decided to work like they were supposed to. Got ham fisted on them to see if they would work or fail. They’re still working correctly a month later. I did warranty them but the replacements were 2” longer than the set I had so figured I’d try to avoid looking at stuff that would piss me off.
T
TheClaw
Chicagoland
I can mix up some ATF and acetone, I might even have some laying around already pre-mixed, and let it soak for a little while, see if that works.
Otherwise I can go to Lowe's.
Many thanks for all of the suggestions.
rust in the eye
Chicagoland
Agreed, but. Ace stores are independent franchises. The cost of that now unsaleable set comes out of their pocket. Unless THEY send in the defective tool for replacement themselves. Meanwhile they sit on unsellable stock and the potential for the replacement not to match.
I see why they resist, don't agree but understand. They choose to sell a legacy brand which works both ways.
whateg01
doo dah, kansas, usa
Craftsman website is easy to use. The only part I had trouble with was purchase date. Best guess was good enough. Except for a cancelled shipment due to low stock and having to email about it, no issues and the replacement ratchet showed up a few days later.
I get sometimes we want to do stuff in person but I don't understand why people are scared to use the web when it makes life easier
E46 Tony
The replacement is going to be Indian or Chinese trash. What's your time worth?
This is almost an equivalent:
$10+S&H on eBay
A lot of the Old Craftsman ratcheting wrenches were the same as Armstrong.
Jaeger is Chinese but not half bad. I bought the reversible and flex heads a couple of years ago mostly for the large sizes in the sets and they're decent. Not as smooth as my Blackhawks or Icons but perfectly usable.
Steve_P
$10+S&H on eBay
The position of the box end in that picture doesn't actually help the "USA quality" argument; it looks far worse than the Gearwrench China made wrenches I've seen.
dyermullet
TX
If my set of tools started out as a matching set I like to try to keep them matching. So I can understand trying to find an inkind replacement. I would be okay with the brand stamping being different if it was the same tool. I would buy the Amazon linked above and also try to return my broken one on craftsman website. If the replacement from craftsman is different model you will still have the inkind Jaeger to complete the set.
finn
The UP, God's country
SBD bought Craftsman 9 years ago. There was a lot of discussion about warranty at the time, and some issues were reported during the transition period, but here we are nine years later, and by almost all accounts the system seems to be working with few hitches.
Lowes works, the telephone number works, and the website works.
That’s pretty remarkable, since we’re talking about tools that are ten to probably forty or more years old, and mostly purchased at bargain basement prices.
And you don’t even have to chase down a tool truck.
cherrybomb
Near Madison Wi.
Is gas free where you live? You've gone to Ace you're going to Lowes and Amazon has a replacement for $5.00 https://www.amazon.com/Jaeger-90-To...-Hardened/dp/B0F7NXP833/?tag=atomicindus08-20
Here's reality: WARRANTEES MEAN NOTHING.
Totally agree,sometimes it pays to evaluate the situation, how often you use this particular tool,can you wait a day or week to get an replacement?In my case,graduating from the school of hard knocks,my tools don't always brand match,but I've learned sometimes buying once,cry once.
T
TheClaw
Chicagoland
So, the other day I sent a message to Sears through their warranty site. I got an email response yesterday asking for additional details, like my full name. Waiting to see what they do.
whateg01
They won't do anything until you give them your name.
Did you not fill out the warranty form? It's almost like it exists just for this sort of thing. Smh
T45
They're maybe probably going to dox you and add you to a list... :D
finn
It’s doubtful he actually contacted Sears. Craftsman warranty is handled through SBD, and has been since Sears declared Bankruptcy. The SBD purchase included warranty obligations.
whateg01
He could have contacted Sears. There's still a Sears.com. of course, the likelihood of this getting resolved that way is pretty low.
cody1325
Southwest Virginia
After getting the run around at Lowe's, I started just emailing Craftsman and having them handle it. They typically would just send me whatever broke (which, coincidentally, has been all SBD-era stuff aside from one 1/4 ratchet I found broken).
Ohio Andy
Columbus, Ohio
Man I know some people that will drive 2 hours each way to save $20 on shipping I don’t get it
For some people it is often part of the game / fun.
I knew people that would make a 4+ hour drive (from Detroit area to Columbus Ohio), stay at a hotel, then drive home just to shop at a specific Mall for the experience.
mikey03
Damn I never been to Ohio is there some real special mall in Columbus?
Ohio Andy
Columbus, Ohio
My opinion is no, but they do have a couple of nice ones.
Ironically, that mall no longer exists in the same form. First people wanted insure malls (it was indoors) then outdoor became the thing and that mall tried to become an outdoor mall.
It blew my mind when they told me. I think it was called the French market.
The previous "nice" malls are mostly gone replaced with things further out.
But if you make it out, hit me up and I will feed you.
cherrybomb
Near Madison Wi.
Look what arrived by UPS today.
A little puny vs the original, still got one nonetheless.
Looks like you got some closure! I'm at the age I don't have the patience to chase,I just bought a Mac short ratcheting wrench ,the size I use often off their website,buy once,cry once.Your problem brings back old memories of Sears,buy a wrench,break a wrench,take it back,new one,no questions asked
