Butane Micro torch
richfinn
Leeds, Yorkshire, England
Any recommendations for a new Butane Micro Torch??, I'm tired of cheap junky plastic ones that dont last.
Mostly used for lighting cigarettes/heatshrinking automotive wiring repairs and other types of hacks which require melting plastic
javyLSU
New Haven, CT
May be overkill, but I love my Snap-On Torch300 and use it for what you list and more. Lights on first trigger press, every time.
beelsr
NE PA, USA
blazer gb2001
$50 so only triple the price of a cheapo HF one. And since it's Made in J.A. Pan, it's quality. Mine lives on the bench and is used for something almost every day - heatshrink being one of its core duties.
dodge610
North Canton Ohio
I got this one off Amazon very pleased with it and didn’t break the bank $35 to &40 dollars.
R
richfinn
blazer gb2001
Interesting, I like Japanese tools in general I will take a look
Thanks
plinker
Northern Wi
MarineScott
W. Pennsylvania
I have tried many, from tool trucks to auto parts stores, and the best in my opinion is Bernzomatic $26 from Lowe's. This one has lasted the longest.
txvwnut
Bedford, Texas
I’ve got a Powerprobe micro torch and it’s been the best I’ve owned. I also have a couple different versions made by Master and they all started leaking after the first refill.
After seeing the post below mine I’ll edit, I’ve had my Powerprobe torch for ten years probably more. It’s not made from cheap parts, more metal and ceramic than plastic. The master torches I’ve had did feel cheep and pretty much are compared the Powerprobe.
CR888
Problem with all the cheap ones is they use a metal nozzle then use a plastic fastener to couple it too the rest of the torch. When they heat up the plastic melts and its in the rubbish bin. I don't agree with all the recommended models in this thread. Rubbish ones work great untill they don't work. It would be good to hear from members that have used them over longer periods therefore properly verifying that the quality is good. Good ones are much harder to find. The cheap ones are easy but not so cheap when they stop working or catch on fire!
R
richfinn
I couldn't really settle on a micro torch in the end so I decided to upgrade my gas soldering iron for a Portasol
kit the can be used as a torch as well.
Portasol is very reasonably priced in the UK
