Hey guys so I purchased a 8ft work bench at Sears for my father for his garage to replace the existing work bench that we've been using.I am looking to have a top made or just cut to size to fit against the walls.The last work bench had gaps and tools and everything else fell off on the side or behind the work bench.So I want the new top to fit flush to the 3 walls where the bench will sit.
Ideally I would like a butcher block but I dont have big money to spend.A butcher block for this bench would run about 400-500 bucks.Anyone have any other suggestions or pictures of where I can get something like this done or what material can be used?? The Dimensions of the top are 103 and 3/4 inches long by 26 inches wide and thickness well what do you guys suggest and what can I use???
For those that are wondering this is the bench frame:
Bench Frame
Bench Frame
Typically people use a clear finish on butcher block, and one that can be more easily repaired.
