Buy another?.. or modern day electrical junk
hiccup
W.Ky
This 6 outlet adapter by Eaton(good brand right!) ..It plugged into my oultet just fine but it ***** when you go to plug a cord into it..It's like trying to push a clothespin through leather..Im actually oiling the pronges to get use out of it till I find an alternative..bout ready to bust it open and see what wtf is going on..anyone else have headaches with these😖😡
whateg01
doo dah, kansas, usa
I suspect the innards are like any power strip. Just bent brass contacts with plastic studs melted into holes to keep it in place. I think the problem is that they want to make sure what you plug in doesn't fall out so they make it super tight. The issue I've had with them is unless it's one where the center screw holds it to the outlet, it pulls out of the wall before your cord pulls out of it.
Shiftless
East Bay SFO
Yeah, I have used those and have the same complaint. I suppose they’d be Ok for a place where the same stuff is always plugged in like lamps and TV’s and such. Lamps yes, vacuum cleaners no.
H
hiccup
W.Ky
Ok..so I plugged and unplugged each about half a dozen times..much better... jeez I better find the Ben Gay now🙄
oiling the prongs? you cant be serious :eek:
BrandonV
Arizona
I once took apart one of those HF power strips and the buss bar setup is so freaking scary it will make you want to buy quality strips.
wastedcosmonaut
Normally people don't complain about things being too tight.
Normally the have plugs falling out. Better to be too secure than not.
Chukster
Cary, NC
And this is why when we made the apartment downstairs for our adult daughter, I spec'ed that every outlet box would be a quad; old duplexes became quads, new outlets became quads. We now have sooo many devices, cords, wall-warts and such, we need more outlets.
KansasArt
Kansas
You’re using the wrong kind of oil. Should be using axle/bearing grease. Slather it on! Guaranteed to slide in easier. And then it will melt the insides so it won’t fall out! 😱😂
Crazyjake8493
Upstate NY
Is it possible that the adapter is working correctly and you're just used to worn out receptacles where the plugs start to fall out on their own?
I'd throw it out, and replace that box with a 2-gang box and two duplex receptacles. If that's not enough, make it a 3-gang box.
Lassen Forge
I got a lesson yesterday in just HOW different stuff is here VS there...
Everything here is modular. You buy the sockets, the mounts for them, the face plate it attaches to, and the box. They all press together and click. I went to take a schuko socket out of it's mount and replace the faceplate, I put the screwdriver in the wrong "click point" and instead of rremoving the socket, I opened it up.
Now, in the US, you open a socket, you have 3, maybe 4 pieces that all go back together in a logical order. This thing presented me with a handful of small and unwieldly pieces that apparently not only go together in one and only one way, but need the assistance of an anti-gravity unit.
I effed with it for a bit, and realized my time was worth more to me than futzing with this damned near impossible to assemble POS (I mean, it HAS to be possible, right??) for an hour or 2...
Fortunately I had a spare I didn't pop apart, but still... damn...
Norcal
A lot of those products are made in China, I trust their electrical products as much as their food products. Remember the pet food and milk scandals?
KansasArt
Kansas
No matter where something is made, it’s just being manufactured to the specifications provided to them. Blame the US companies for wanting cheap materials and almost slave labor to increase their profits.
