Buying A Bandsawmill, Any Recommendations?
Renegade1LI
long island ny
I really don't need one, but I have some trees to take down that would be nice to mill into lumber. Some hardwoods for new kitchen cabinets, pine to reside the shop, build new shop, shed. I probably need my head examined but there are worse things to do. Who here has one or could recommend one, probably 26", would like to cut up to 16' boards. Not in a rush, just starting to look, haven't looked at used yet, but will, thanks.
PCustoms
VT
What's your budget?
You can easily spend $30-40k, mill the lumber, wait 5 years to air dry, find a wide planer and then start building your new cabinets.
Tom Sestito
Winnipeg, MB
I have a Woodland mills HM30MAX. Love it. Was about $8k CDN to my door when I bought it a few years ago, and I bought the sharpener with it.
It was easy to assemble, the instructions were great and the saw has been performing very well. I have about 20 hours on mine so far so I haven't used it a ton.
ALinCarolina
NC Piedmont
No offense but if it is just a dozen trees or so I don't think it is worth it. Can you post some photos of said trees? For nice usable boards the trees need to have a straight trunk with no branches until way up the tree. This generally only occurs when the trees are all growing close together. You will have a percentage that are low quality boards regardless. Then you will need to prepare a place for drying them, stickering, etc. Plan on one year of drying per inch of thickness. For siding the quality doesn't need to be high but for cabinets they probably should. If air dried outside you will ideally need to let them acclimate to the inside humidity levels. I have a complete shop so can joint, plane, etc. so when I was building my new shop on a thickly wooded site I had the trees cut and kiln dried by a friend. I still don't know for sure if it was all worth it.
R
Renegade1LI
long island ny
What's your budget?
Budget is about 10k, not totally sure if this is a good idea, but may be a fun hobby. I can see this getting out of control, building a shed for it, drying area, etc.
R
Renegade1LI
long island ny
I have the tools and space to do it, trees are good for milling had a local tree guy come buy. Might be fun, might be a bad idea, I'm still in the thinking phase.
You should definitely read here then
southalabama
Brewton AL
You aren’t going to get into a woodmizer for $10k IMHO
After a hurricane a friend had about ten acres of pines down. He couldn’t get a logging crew because everyone was so busy. He bought a woodmizer. He cut his trees and subsequently sold the mill for what he paid. I helped him run it a good bit.
R
Renegade1LI
long island ny
This is what I'm looking at, a little more$
R
Renegade1LI
long island ny
Thanks for the link, that's a nice machine and good value, worth looking into.
RivennHewn
PNW
Thanks for the mention!
My only recommendation would be do your homework.
I love milling, but it takes time, space, and funds.
Mission creep is real. There is always “one more” tool or accessory that will “change your life” 😜
R
Renegade1LI
long island ny
You're talking me into it, another tool that needs more tools, love it. I am seriously considering the wm126 seeing good reviews on it.
RivennHewn
PNW
A bit anecdotal, but my experience with Woodland Mills has been very positive.
I’ve heard how great Woodland Mill’s customer service is, but truth is, I’ve yet to need it.
My first advice is to not take assembly as a speed challenge. The more exacting you are, the less problems you’ll have later.
Read, and more importantly, understand the assembly instructions. One benefit is you’ll gain a great understanding of your machine. This will help when you do have an issue.
All machinery has maintenance requirements.
Stay on top of the maintenance, and high quality lumber will result.
Feel free to DM if you have any questions.
PCustoms
VT
I don't have a mill (yet) but I do have a stump grinder that I bought used.
I sent them an email over the weekend with some parts questions, and by the next Tuesday had a reply. Might have even been that Monday...
southalabama
Brewton AL
My friend had an LT35 with hydraulics on a trailer and a blade sharpening tool.
cgrutt
My buddy bought a wood mizer a couple years ago but believe it was in the $30 - $40k range. I'm not sure which model it is but here is pic.
The building that it sits in was milled on it. All the wood (except for a small amount of cedar) was harvested off his property.
This outhouse was one of many projects I've posted it before.
He has big plans to build a number of cabins on property but hasn't started on those yet. All the wood will be harvested and milled on site.
glennm
Whatcha cutting there?
We had some nice spalted birch (a couple of logs) and a nice cherry that has some rot in the middle. We also cut up some ash to keep the pile level. It’s piled in my chicken coupe, gets nice and warm in there on the sunny days.
R
Renegade1LI
long island ny
That Will be next, making a drying room, saw some good ideas with a conex box.
