Would you buy a used welder? I found one on the local craigslist that I think would serve my needs well. It's a Miller, but there's not much info in the ad. The title says "Millermatic 135/175 & M10 gun". I'm not sure why it says both, but on the inside of the ad it says "220V, with cart, used very little, purchased 10/03". He's asking $425. I've never bought a welder before, but my best friend kept his in my garage for years (now he's got his own garage so I need to buy my own welder), & that was a Lincoln Weld-pak 155, & that seemed big enough for everything I needed. I guess I'm just looking for advice from those with more experience. Would you buy a used welder? Anything to watch out for? Does this seem like a decent deal?
When my buddy first bought his Lincoln, he used flux wire for the first year, then changed it over to gas. Can you even buy the Miller for flux-core, or are they all set up for gas? (I don't know yet if this one is set up for gas or flux, but I want to run it with gas, so I may need to consider the added expense if it's not already set up for it. The picture doesn't show any tanks or regs). Thanks for any advice!!!
But if it's 220V then it's gotta be the MM175. If he can't tell the difference between 110 & 220, then he really shouldn't be working on streetrods, or anything else. But I'm going to take a look at it tonight, and see if it all looks & works good. I'll let you know how it goes, and thanks again guys for all your help!!!!
