Mario428
Been rolling my C-4's around on the bench for years and it is a major PITA so since I have time now I decided to build a holding fixture. Had to clamp onto the case so that I had access to 3 sides of the ******. There are 4 lugs on the case so I decided to use them. Try # 1 was such a disaster I refuse to show any pics of it. LOL
This is try # 2
Hooks into 3 of the lugs, one has the tailhousing bolt going thru it so not enough lug to get a hold of. So I have to drill a hole in every ****** I work on. Still lots of thread for the tailhousing bolt.
On the other 3 I slotted a pc of plate to fit inside the lug, then the nut on the threaded rod is adjusted to get the fixture tight on the ******.
I drilled a hole in the face of my bench I slide the fixture with ****** attached into. I have 3 index positions, pump up, VB up, tailshaft up.
That is a complete ****** mounted there, I gave it a good shake and it is solid as a rock.
Still needs some clean up and paint but I am a happy boy now. LOL
This is try # 2
