CobraChevelle
I think I am going to go with a C-aire compressor since I can get them through my work @ cost + 15% which will bring it down much cheaper vs any place online or local.
My question is, I dont know which to get.
We don't sell alot of compressors in general. But when We do they are for small repair or body shops.
1.) Part #: A050V060-1230
5 HP two stage pump running at a low 673 RPM and an output of
15.1 CFM @175psi. 60 gallon, 200psi certificed tank.
2.) Part #: A050V080-1230
5 HP 2 stage 17 CFM @175psi running @ 885 RPM
80 Gallon Tank.
3.) A075V080-1230
7.5 HP 3 cylinder 2 stage 24 CFM @175psi, pump speed of 649 RPM, 80 Gallon Tank.
( ^ This is the one we sell 99% of the time but these customers use this model to make a living)
Is it worth it to get an 80 over a 60 gallon??? I plan on doing some body work and repainting some cars in the future. Most of the time I plan on using this for auto repair work.
I would like to get the 7.5HP 80 gallon but first Of all I need to make sure I can even run this thing in my garage without buring up my wiring. If 80 gallon is a better choice then maybe the 5hp will be all i need??
80 Gallon Tank.
3.) A075V080-1230
