C Clamps, anyone?
Jason280
I picked up a few C Clamps from the pawn shop this week, and have a few questions. One, on the clamps below (far left), is it possible to replace the missing swivel pad? I know it may not be worth it on the Chinese clamp, but may be on the Wilton.
Also, any idea what these clamps are generally used for? One is a Wilton #4, the other is an Armstrong 78-030. To call them beefy is an understatement, they are certainly massive. Are they very expensive?
cmandp
New Jersey
Nice finds. I've seen those mystery clamps used to secure the main and cross beams together when moving houses. Not sure what they're called.
J
Jason280
My plan when I bought them was to make a couple of small vises out of them, but may just keep them as is.
LumpyMusic
Phoenix Arizona USA
Do the big monsters look like they ever did have pads? They look sort of like U joint (or similar) presses, which typically don't have pads but mate with various sized bushings and adaptors to fit the appropriate bearing being pressed.
They obviously aren't U joint presses of course becaue the opposite face is flat. But perhaps something similar? Particularly becaue the "handle" end is wrench flats instead of a sliding bar.
Lumpy
You were on CHiPs? Did you wear those ****
tight pants and high boots like Erik Estrada?
No. Swimtrunks.
www.LumpyMusic.com
dr_clyde
Holland, MI
Those beefy clamps are used a lot in lifting and rigging. Crank em down on drum or plate of steel, run a sling through the clamp and lift with a forklift or a bridge crane. Useful if you do that sort of thing. Kind of clunky to use as a regular c clamp.
J
Jason280
Interesting. I was able to get the clamps cheap, $40 for all four.
machine_punk
Napa Valley, California
There was a thread recently on replacing swivel pads on C clamps...I seem to remember McMaster Carr has generic swivel pads in several sizes.
I don't have personal experience with the other C clamps, but they look a lot like the the clamps used by iron workers to hold steel beams in place, while they fasten them with something else (welding, bolting, riveting, etc.)
M_P
The big heavy clamps are known as bridge clamps. and did not use pads, like regular C clamps. As mentioned, used in heavy rigging and ironwork. They often will not fully close.
Larger eplacement C clamp pads, are available are Mcmaster or Grangers, possibly both.
J
Jason280
I'll have to check and see if I can get a pad for the smaller Wilton, but I doubt I will do much with the Chinese clamp. If anything, I might weld a large washer to it to use as on brake pistons.
toolmiser
La Crosse, WI
I had a few that were missing the pads, not knowing about replacement ones, I welded a short chunk of pipe to a washer, and then cut slots near the other end of pipe. I placed it over the clamp end, peened them a little the tack welded the kerfs together. They work pretty well.
woody 73
The Great State Up North
yes you hit the big one for paying $40.00 dollars for those Very,Very expensive Heavy duty clamps! but they are not used by woodworkers for obvious reasons. I see the city workers lifting large large plates using those clamps when they are reparing the roads.
srmofo
SW ohio
M_P
The thread was called c clamp junkies. I started it, if you want to go looking for it
rodm1
Tool and die makers use then daily to move heavy plates around.
