C-Wire for Smart Thermostat
Plump
SE Wisconsin
Ordered a smart thermostat through the local power company with a $100 instant rebate. Getting my ducks in a row and want to start with the wiring. I've got an OLD house (1895) with just two-wire thermostat wiring to my gas fed boiler. No AC, no fan.
Can I pull a new 4/5 wire and just connect it to the C-wire that's in my current boiler. Nothing is attached to it at this time. Don't want to fry the board and figured you guys would know.
Thanks!!!!
jlv03
SE IA
It is interesting that, what I assume is the thermostat 2 wires, one of the thermostat wires is landed on the "G" terminal. This is typically used to turn on the fan.
P
Plump
SE Wisconsin
I know absolutely nothing about these wire ups so I couldn't fathom a guess on why they used that G wire. It's a boiler so definitely no fan. I should have the HVAC guy come out to do a check up anyway so I'll maybe get an answer from them.
Thanks!
exranger06
CT
Yes, I just did this earlier this year on my oil burning boiler. You really only need 3-wire thermostat cable, not 4 or 5.
rlitman
Long Island
I agree, but the "you really only need" argument is also why the OP now has to run a new wire, because before this smart thermostat, he really only needed two wires (the same boat I was in).
When I ran new wires to my thermostats two years ago, I used 8-wire thermostat wire. The price difference between that and 4 wire was insignificant (especially compared to the effort required to run the wires). Granted, I happened to have certain walls open that would end up closed, so adding wires in the future would be even more difficult for me.
In my kitchen, I'm piggy-backing that run, by using two of those wires to power a cordless phone base station on the other side of the wall (sending the 9VDC over the wires so I don't need to have the phone plugged in right there). Upstairs, I've got 7 spares (the original 1-pair wire is still there too) that I don't know what I'll do with, but they're not in my way...
brewchief
Thanks!
It goes to the G terminal because they are using a common fan center for the circulator relay, very common with older boilers.
Sent from my SM-T510 using Tapatalk
