Working w a retired carpenter to build a 24 x 24 hunting cabin w a 10 x 10 mudroom, 2x6 walls R-19 insulation on the walls 1" dow pink foam boards on the floor and ceiling. Large Fireplace w 2 blowers to heat the place.
8" flue with metal asbestos surface. I can be close to a stud wall with this. Plenty of heat when I touch the chimney wall.
Cabin will be used year around for hunting, ATV, dirtbiking.
Man cave = Generator and Outhouse.
A year into the build
Inside pic is old, wall insulation and some wiring is completed
Here is the ?
Any experience out there with wrapping a portion of outside chimney wall w copper tubing then connected to PEX for in floor radiant heating, looks like I need to plan for circulation pump, expansion tank. Could be 1 large zone? During the week the place could be vacant and temp there this week at nights is below zero.
I am confident the stove will give me plenty of heat, but If I can do this as a simple add I want to pursue.
Thoughts?
Here is the ?
Thoughts?
