Cabinet door/hinge Advice
STIBuilder
Washington State
Looking for a little advice on making doors for this material cabinet im building. I know i want to hide the hinges but not sure if sliding doors, or swing out doors would be best. The opening is 57x34.5 with the 1.5" 2x4 box face.
NUTTSGT
Northern Central Ohio
To hide the hinges, you might want to check into "european" hinges, well atleast that's what they used to be called.
I'd rather have doors that open than doors that slide. If you use sliders, you can only see into one side as the other door slides in front of the other.
