Cabinet Height
james1savage
Calgary, Alberta, Canada
I am by no means a carpenter so this is probably a stupid question...but I'm going to ask it anyway.
What sort of height do you guys go by between the top of your workbench and the bottom of any storage cabinets above your bench? What kind of distance between them do you find provides good working area and still be able to reach the shelves?
Thanks for your input.
jweller
depends on your height. IMHO you should be able to reach the top shelf without a ladder/stool. After that I set them as high as I can. You never know when you will need to work on something taller, and getting them up gives you a little extra room for an under cabinet light
dittle fart around
Vancouver, Washington, USA
If you want a good example go to your kitchen and copy the dimensions. Depends on how deep your workbench is also. Most kitchen counters are 24 inches deep. My workbench is 32 inches deep with 24 inches of pegboard on the wall and 12 inch deep open shelves above.
gtcs1
Hi James
The top of my workbench is at 39 1/2" from the floor and is 29 1/2" deep. The bottom of my upper cabinets are at 22 1/2" above the workbench, they are themself 33"W X 17"D and 22" H.
The spacing between both suits me fine.
