kaffine
I am trying to replace some wire in buried conduit but it wont budge. The conduit is 1" RMC and is full of water. The cable is 18 awg 2 conductor tray cable.
I have tried to run a fish tape through the conduit I can get about 70 feet from either end before the tape stops.
I am not sure how long the conduit run is I know it is over 120 feet but not sure how much over. I figure there are at least 270 degrees of bends could be more. Not sure on how it is routed underground I know they didn't run it the way I would and it isn't run the way the plans show either. The conduit has been in place for around 20 years not sure if the cable has ever been replaced or not.
I have seen Polywater has a lube that is supposed to help loosen stuck cables? Has anyone tried it and does it work? I could fill the conduit up with the lube then use a fish tape to try and spread it through the conduit more.
Any ideas on how to get the cable out? I have thought about getting a sewer jetter and trying it to clean the conduit out.
Also any suggestions on how to clean the conduit after I get the old cable out and before I pull new cable in?
Thank you.
Thank you.
