VinceK2
I have a shed that is attached to the house. There are two 110-volt NM cables that now lie on the surface of what used to be the house's exterior wall. Siding was removed, so the cables are on the sheathing.
I was told by an "electrician" that I met at Home Depot that that is done all the time - because it is a limited-access, low traffic area.
One cable is for lights in the shed, plus a GFCI-protected outlet that powers battery chargers and outdoor low-voltage lighting. The second cable goes to an upper-floor bedroom to provide power to a small window air consitioner.
So, is it OK?
If not, can I enclose the cables in schedule 40 tubing and fittings? Would half-inch be OK, or should the tubing be three-quarter inch?
What about Wiremold channels?
Thanks,
Vince
So, is it OK?
Thanks,
Vince
