00si2
I'm having my concrete poured this weekend and am looking for some info about adding calcium to the mix. My contractor wants to use 1%. He would like to use it to speed up the set time so he can get a good finish on it. The temps will be in the mid 40's for a high. What are the cons with using calcium? From what i have found it slightly reduces the cured strength and it can cause steel reinforcing to rust when used in a higher percentage. Is there anything else i am missing? Is it going to cause any problems with an epoxy finish later down the road?
