SGKent
It is late and forgive me if this question is asked 10 times a week.
I have a main panel. This is single phase residential. On it are a pair of 30 amp breakers that supply power to a sub-panel breaker box in a shed that is about 10 feet away in wire length. In the shed is a locked pair of 15 amp breakers for a compressor and a single 15 amp 120V breaker for a light and a 120V 15 amp socket.
Q1. At 240V. Do that pair of 30 amp breakers in the main panel supply 30 amps each breaker = sixty amps combined or would one or more trip if the current exceeded 30 amps at 240V? Example - could I run two 10 amp 240V devices in the shed and still have a 10 amp safety margin?
Q2. At 120V. Do that pair of main breakers supply 30 amps each at 120V = 60 amps at 120V or because they are a pair locked together are they 15 amp a breaker and just marked30 combined? Each reads 30 amp with a bar between them.
Q3 What would be the optimal wire gauge used between the main breaker panel and the sub-panel with that 30 amp marked pair of breakers going to the sub-panel? 10/3 with a ground plus a grounding rod?
What I am having trouble figuring is that the breaker pair in the main panel are marked 30 amps. Is this 30 amps across each one to neutral so really this is 60 amps total at 120V in the shed? For example, when I have a 125 amp panel coming into the house, is this 125 amps on each leg of the 240 or 125 amps across the two legs so really only 62.5 amps between each leg and neutral?
