calculating btu load
2011laramie
Central Alberta
So my garage is already complete but im just curious as to how often my heater runs and how long. I should be able to just use a "Kill a watt" 110v meter on the cord to my modine 45000 btu heater. If I leave it for a week it should have a total kwh used for how often the fan runs correct? Based on the number of hours used per week I should be able to calculate a rough estimate of my btu used.
Stuart in MN
Minneapolis
Does that heater burn fuel, or is it all electric resistance? Does the fuel consumption modulate (vary with time?)
That heater burns gas, so the Kill-A-Watt will only monitor the electric fan. However, he can use that to figure out how much it runs in a week.
2011laramie
Central Alberta
Ordered up an meter. Hopefully it arrives while the weather is still cold so I can see how often its running in this cold snap.
KoRNTERA
Don't forget to calculate for efficiency.
45,000 BTUs X .8 is 36,000 output BTUs assuming its 80% efficient. Keep in mind it will only average your heat loss.
No need to run it for a week just go out on a cold night and watch in run for 3 hours and it will give you a good BTU loss of the structure if that's all your looking for.
2011laramie
Central Alberta
Ya I didnt forget about the efficiency calc. Im just doing this to compare my rough calc for heat losses vs recording the heat loss using my heater run time.
