calculating how much stone I need
casmurbax
Wilton, NY
I am finally starting my 18' x 24' garage build.
I feel foolish not knowing how to calculate the amount of stone I will need for the inside perimeter of the monolithic slab:dunno:, everywhere else I can calculate how much I need us.
Any assistance in calculating this.
Also, how much stone should I add to the amount I need to compensate for the compaction of the stone to be at the 6 inches of height? I will be using a narrow plate come compactor centrifugal force of 3550 lb.
Thank you.
ard
No image.
LxWxH? >>cu yards. compaction, 10-20% (probably too much, but depends on what 'stone' you are asking about) Excess onto wherever you will be placing the driveway, later, after all construction is done.
C
casmurbax
Wilton, NY
Ard,
Thank you, hopefully I fixed the image issue.
Maybe I am just over thinking this calculation because of it being sloped? Like a parallelogram.
I will be using #2 stone.
steveo1o9
Eastern MD
That area you hatched is approximately 0.75 SF, then multiply by liner feet to get your volume of stone. The easiest way to calculate that is to break it up into a triangle at each end and a rectangle in the middle. You will need to use some trigonometry to determine some lengths not given. I cheated since I am already in the middle of using CAD so I just redrew that area to find out.
jimchevy
Most stone yards will ask what your application is and look at their cheat sheet.
Bondo
Greenfield, Maine
Ayuh,.... 18' x 24', / 2, / 27 = 8yds,...
Get 12 yards, 'n you'll have alittle bit of stone left over,...
If yer supplier sells by the ton, that's 'bout 15 tons,....
