Calculating Landscape Rock
D45
NW INDIANA
I just finishing the brick edging around the deck and pool (359 bricks), and put down a ton of 6mil plastic underlayment
Now it's time to order some river rock.......an accurate amount too
Any tips or trick so I'm not short on what I need and also don't have alot of leftover
mike93lx
Richmond, VA
Calculating the volume is pretty easy. Length x width x depth. If length and width are feet and depth is inches, multiple all those numbers and divide by 324. That will give you the volume in yards.
The challenge is having the yard hit that number.
nolimits76
Oklahoma
If you are getting your rock from a quarry, then you will likely need to know tons.
Math is easy. I always use FEET. An example below.
How much rock to fill a 10’ x 20’ x 6” thick area?
First, convert 6” to feet, 6/12 = 0.50’
Now let’s get the volume. 10’ x 20’ x 0.5’ = 100 Cubic Feet / 27 = 3.704 Cubic Yards
If by chance you had a funky shape and did an onscreen take off to obtain square footage, you can also multiply SF x thickness to gain volume.
200 SF x 0.5’ thick = 100 CF
The safest way to convert to tons is to call the quarry and ask them the weight conversion factor for the specific rock you are purchasing. We use a lot of different sands and aggregates in our business so the weight can vary from about 1.25 to 2 tons per CY.
Once you know the conversion, simply multiply the cubic yards to determine the amount. Let’s just pretend the quarry tells you 1.75.
3.704 CY x 1.75 = 6.482 tons
I’d likely order 7 tons. If you are buying from somewhere like Lowes, they sell some landscape rock in the bag by CF or CY. Either way, the math above will get you what you need. Just be clear what units (CF, CY, TON, etc) you need.
D
D45
NW INDIANA
Thanks, looks like I need to get some measurements and decide what type of rock
I removed like 30 wheel barrel loads of medium sized river rock
Larger river rock seems to be harder to shovel and get level
D
D45
NW INDIANA
1 ton covers approximately 120 sq ft @ a 2" depth.
That's for medium river rock
FredWanaker
NorCal
also don't use solid plastic. Use a landscape fabric. 3 reasons, (1) it will allow water to percolate thru, (2) it will allow air into the soil and not bring roots to the surface (3) when you pull it up, which you will someday when dirt piles up in it just from that dirt which blows around, it will be easier to clean up the rock and pull up the old liner. Plastic rots and when it does it is a forever mess to clean up. If all you want is a barrier to weeds then just use cardboard or three or four layers of newspaper. My first harsh lesson in life as a teen was don't get volunteered to clean up rock landscaping that has dirt in it. And no matter what you do, over time it will get dirt and debris in it.
nadogail
Coronado, CA
I suggest you round up rather than down, in my opinion a little excess rock is easier to deal with than a shortage that will require a 2nd trip to the store or worse; an additional delivery charge.
D
D45
NW INDIANA
I used solid black 6 mil sheeting at my friend's house, over 20 years ago. No issues at all with it
Fabric never holds up and seems to not prevent growth
Grant F
SW PA
I would strongly encourage you not to put plastic sheeting under the rock (for the reasons already mentioned). Also not a fan of typical fabrics under rock. I would recommend using a woven geotextile fabric under landscape rock. You can get it in 3 or 4 foot rolls from Amazon. My landscape supplier has it on a 12 ft wide roll and sells it by the foot. My landscape supplier has always been able to tell me how many tons I need based on a rough square footage.
Bent Handle
Iowa
I’ve installed hundreds of tons of river rock.
1-2” rock we get about 100 sq ft per ton. If you go larger rock, it needs to be deeper to not see gaps or mixed with smaller stuff.
We only use DeWitt Pro 5 landscape fabric, I would personally never use plastic of any sort.
D
D45
NW INDIANA
A stone company told me that one ton will cover 150 square feet, but I guess I need to figure out cubic feet.......
When it gets delivered, do I need to be concerned with it being dumped on my driveway and cracking anything?
D
D45
NW INDIANA
Here's my rough sketch of the area I need to be covered
I come up with roughly 520 square feet
D
D45
NW INDIANA
I ordered 6.25 tons , delivered today
Should be done tomorrow and I'll have some left over
Bent Handle
Iowa
I get about 100sq ft per ton at 2.5”. It really does depend on the rock size and type though on coverage. Better to have to much than not enough! Until the end when you’re sick of moving it and you’ve still got a pile :). We get rid of a lot of our job site removals and leftovers free on Craigslist or facebook.
nolimits76
Oklahoma
Use this an opportunity to improve your original design. Maybe smooth out some of your transitions in your original sketch or add a little “kick out” and plant a tree.
D
D45
NW INDIANA
No thx.......I appreciate the input though
Used all 6.25 tons, just made the layer under the deck thicker
