Calculating power use.
Reg1952
Ontario Canada
When I am figuring out how much power my florescent lights will use do I add the bulb wattage and the ballast wattage together to get total usage. Or does the ballast just use power when starting? eg. 2 32 watt bulbs and a ballast that draws 1 amp(120 watts) = 184 watts per fixture? Am I doing this right??
zkling
How accurate of a number do you want? Do you have a clamp amp meter?
sberry
Brethren, Michigan
I am with zkling,,, what are you trying to do? This is just an easy deal. When I size most circuits I figure 100 watts to the amp. I realize that is not correct but its super easy no miss way to leave the headroom without havin to do a bunch of figurin.
R
Reg1952
Ontario Canada
Just trying to get a rough idea what type of wattage 12 T8 fixtures with 2 bulbs per fixture would pull.
ddawg16
S. California
Assuming 32w bulbs....24 bulbs x 32w = 6.4A....
Assuming you don't want to exceed 80% for a continuous load...even with a 15a ckt for lighting, your fine.
R
Reg1952
Ontario Canada
So if I times .786 x 8 (8 hours a day) = 6.288 kw x 12.9 cents a kw = 81.11 cents a day to run my lights?
