I’ve got a 6yr old 10gal CAT-10020 air compressors that started acting up this weekend.
At first I noticed the air compressor didn’t kick back on when the pressure dropped during use. Come to find out the breaker tripped and so I reset it (it was an odd thing to occur since only the TV and compressor were on that circuit at the time). I restarted it and a few minutes later It tripped the breaker again.
I reset it again and this time noticed the cold start valve never closed (meaning the air that the compressor was building was constantly leaking out). This valve is designed to close shortly after start/pressure is built. Because this wouldn’t close the compressor kept running - the pressure gauge stayed around 10psi and I can hear/feel the air coming out of the cold start valve.
Does this sound as simple as a cold start valve replacement, or is the fact that it tripped the breaker twice a sign of something else that I should check first? The compressor wasn’t on long enough to suggest overheating caused the breaker to trip.
Background: It’s been sparsely used, is never stored overnight with air, and has been a great compressor until Sunday.
