California Air Tools
IRQVET
Forgotten Coast (FL)
So before quite air compressors were mainstream, I remember picking up a California Air Tools (CAT) 10g/2HP air compressor. It was super quite and seemed pretty well built. I remember the first one I owned developed an air leak from a bad air rail system. I contacted CAT and they sent me a replacement part free of charge within 48 hours. They were pretty seamless to deal with as far as if you have a product issue.
Owned that CAT for 7-8 years and I abused the piss out that thing, asking it to do things it wasn’t designed for (like sand blasting) and it just kept coming back for more.
I’m now on my 2nd CAT compressor and the quality and performance is still the same, highly recommend them.
My old 10 gallon (left) and my new 20 gallon (right).
Nessism
Torrance, CA
Love me some California Air Tools compressor. Got me a 5.5 gallon, 1.0 hp jobby, that's my daily driver in the shop. I've also got a big monster 80 gallon unit for media blasting, but the small quiet California unit gets used more regularly.
westracing01
New Milford, CT
My old two horse, 20 gallon hodge podge got a pin-hole leak in the tank so I figure it's time to replace. I'm kind of torn on these two...
Or the bigger...
I'm really only running the compressor to fill tires, blow off stuff and run the air impact gun. I'm unsure if the larger 20 gallon compressor is really needed, plus I like the idea of the aluminum tanks and no rust to worry about.
Thoughts?
I
IRQVET
Or the bigger...
Thoughts?
Running an impact on a 20 gallon will be a challenge IMHO. That’s why all my impacts are electric, it was cheaper.
Jeepster04
Bought my brother one for Christmas just to air up tires and the like. Its amazing how quiet it is and it fills up the tank in less than a minute (3 gal). Hopefully it lasts a good while.
westracing01
New Milford, CT
I wasn't having an issue with it on my current, but I actually just ordered an electric impact that will probably smoke my little IR air impact.
I guess it's a moot point now since I'd really just need air for tires, blowing off stuff, etc.
CAT still leads in my mind. I have a 220 plug already for the current comp, so now it's just a matter of finding another one for the small things.
Thank you!
mike93lx
Richmond, VA
Or the bigger...
Thoughts?
I have the first one and like it a lot. It's light enough to be easily portable and it's quiet enough to use it in the house for trim work. It is inadequate for using a blow gun when wood working, but it runs a nailer or fills tires just fine
