Caliper suggestions needed
Mecha
Volunteer State
My Mitutoyo dial has served me well for several years.
Me too. Bought my Mitutoyo 8" dial caliper used off of eBay back in the mid 90's. passed quality calibration at every plant that I have been to since. No play and always zeroes out proper. Love it.
pstemari
Seattle
A smooth slide action is necessary to get a good feel, which is important in calipers.
Get a Starrett 123 from eBay if you want a really nice instrument. Super smooth, extremely rigid. Vernier has nothing to jam or run out of batteries, and with 50 divisions is easy to read.
I've yet to pick up a digital caliper that was worth the bother. Tesa/Etalon/B&S wins for dial units.
Sent from my Nexus 6 using Tapatalk
matt_i
SE Michigan
As far as rebuilding a Sube, one of the least accurate things I trust any dial or digital calipers for is measuring a bore. Plus it can only go ~5/8" deep. If its ever been dropped or knocked off the bench the points are suspect to boot.
A telescoping gage set plus a micrometer is what I would trust. These need repetition until you trust the measurements you are getting are reliable.
Maximum404
Danville, VT
Thank you everyone for your thoughts. I should have been more specific I think in my tool needs. I'll be using the tool to check in/out of spec parts vice using them for actual machine work. I'll be going to a machine shop for any actual work. I would only use the calipers to check piston/pin tolerances, piston diameters, thrust clearance, etc.
