It makes it from 12v?how does the inverter get 120v power?
Unless I'm missing something this is a hodgepodge of parts and not a traditional rv inverter like you're thinking
It is an INVERTER ! I makes its own 120VAC from a battery !how does the inverter get 120v power?
I beg to differ ! Inverters with built-in chargers and transfer switches are a "relatively" new concept, probably less than 25 years old.... this is a hodgepodge of parts and not a traditional rv inverter
Thanks. I don't understand why this was such a hard thing for people to understandIt'll work and most likely be safe but it's not the right way to do it.
So the (best) solution is to switch both hot and neutral and thus, have only one neutral-ground bond at any given moment.
You answered your own question. The best solution is to attach a grounding fastener. The snip is from a Generic 4000XL (not inverter, but answers the first part).No one is going to carry a 6' copper bar and pound it 5' in the ground. What is the "best" "ground" solution when using a generator or inverter.
I think you're confusing ground, with grounding, grounded, and earth. Each has it's own meaning.Related to this whole discussion ... In a camper trailer with a "modern" inverter/charger/transfer switch, if you are NOT attached to "shore power", "ground" is at best the frame of the trailer.
