Can a humidifier be piped into radon PVC mitigation pipe?
Sevenhills1952
Virginia
I wouldn't. My brother's company does radon remediation and my understanding is the pipe goes from under basement slab up through roof with a vent fan. It vents radon trapped under slab venting it outside otherwise radon has nowhere to go but inside house.
Dehumidifier water tapped into that pipe wouldn't be good. Running that water outside or into plumbing drain would be best.
Sent from my SM-S205DL using Tapatalk
dave_dj1
Jackson, NY
I would think it would make a difference what is under your slab IE: rock or something with good drainage. How is the drainage in general around your property? How much water is the dehumidifier producing in 24hrs?
Sevenhills1952
Virginia
Everything serves an intended purpose. The radon system is designed for radon remediation. You don't want to monkey around with it, let it do it's job. My geologist brother's business checks radon levels in a home or business then an appropriate system is installed. Radon levels rechecked afterwards.
Drain dehumidifier the right way for it to work properly.
Wrench97
Southeastern Pa
That would cause the exhaust fan to **** air through the drain tube and not the radon from under the floor..........................
Sumboodie
AK
5-8 gallons for a medium sized unit.
T
TeamTruett
Mid Hudson Valley NY
Thanks for the replies, suspected the answer would be no overall. The dehumidifier removes 50 pints a day and it's a chore emptiying it. My basement was built with "superior walls" which has I understand has pea gravel under the slab and it has good drainage so there isn't a sump pit. I'll keep thinking on this...
mike93lx
Richmond, VA
You could drain into a condensate pump and then get it out with that.
Like this
Little Giant VCMA-20ULS 115-Volt Condensate Removal Pump
SKU# 2044812 25
jack stand
Lakes Region Maine
I understand your thoughts, but a lot of unknowns come into play. First would be that I doubt that you radon piping is installed with any particular slope, this in an extreme situation could reduce the proper cfm flow and possibly end up with a stagnant sluggish pile of goo in the pipe. The sub grade drainage suitability has been raised previously. I'm not familiar with what they use for pipe, fully slotted black drain tile may never "pool" water, but the white sewage pipes with holes on one side may depending on the orientation, something else that I don't know for a radon system.
flan
I also wonder if all the water that you put into your radon system will then leech under the slab creating damp stone which in turn may not help your humidity situation at all, it may hurt it?
jb3
Rhode Island, USA
The unit doesnt necessarily need to be on the floor. I mounted one on a wall and let it gravity feed into a basement sink, so i could sidestep having to dump it out and worry about a pump operating to drain it.
The efficiency loss in air currents was totally worth the gain in drainage simplicity. Still worked great in a wet basement.
Glemon
NE
Couldn't resist, but lots of good suggestions here, our basement is below the sewer line, we have one of those little pumps for the HVAC. Or a regular drain line if close enough.
Sumboodie
AK
Put a condensate pump and run into a drain higher up. They are $30-40.
check251
PA
I drain my dehumidifier with a hose connected to the lid of my sump pit.
The pit and the inside perimeter pipe was installed when the house was built.
I never had a need to install a pump.
The radon system uses the same piping that leads to the sump pit.
jimindm
Des Moines, Iowa
I think it is pretty common around here to use the same piping for both uses.
As I was reading the responses I was think just that. Whether the OP has a sump system or not, wouldn't the radon piping sort of act as laterals for a sump pump.
Any system that would require perforated pipe under a basement slab has the ability to collect ground water. Something has to be planned for that water.
I suppose in rare cases there could huge differences in water tables and the radon companies may have a less expensive option for that.
If the OP system has no way of dealing with groundwater, I would certainly be finding out what the warranty is on such a system. Mother nature has a way of doing things her way.
