hmbemis
Echo PB-580T about 4 years old.
Was starting/running fine one week, the next week the trouble started.
Symptoms:
I found I was getting it to run for a second on carb cleaner sprayed into spark plug hole, so I assumed it's a fuel/air issue, not spark/compression but maybe I'm wrong?
I noticed the purge bulb seemed to be sucking air, bubbles were obvious in the return line (bulb wasn't filling w/ fuel totally, and would always have air in it)
Pulled carb totally apart, cleaned everything, reassembled, same symptoms. Also blew out both fuel lines w/ carb cleaner, no blocks
Tried starting w/ fuel cap off but didn't help.
I assumed my fuel-soaking might be a carb issue... Bought $18 Chinese carb from Amazon, but still won't start -- however this purge bulb acts normally. I will also say, this time couldn't get it running w/ carb cleaner in the plug hole, and the air filter had been wet w/ fuel when I opened it, so I'm thinking it might have been badly flooded at the time by the old carb? Was also only 30F outside.
Aside from finding a local pro, what should I be checking/trying next?
Symptoms:
- If I manage to get it running, it only runs at WOT and is slow/bogged, smokes a lot, dies immediately off WOT and won't restart
- Several times I've found the air filter soaked with fuel after sitting upright/normal
- Pulling fuel line it will sometimes flow by itself until I open fuel cap, even after sitting for days
