Can anyone help with wire stripper advice
ThomasLayne
Hello Everyone
I am looking at getting some new wire strippers, I want to get a good all round wire stripper I can use for most jobs. but which type do you think is best?
I have narrowed my choices too these three:
http://www.newark.com/knipex/12-62-1...8mm/dp/06R6274
http://www.newark.com/duratool/d0162...mm2/dp/41R5485
http://www.newark.com/weidmuller/str...6mm/dp/24M7939
But there are so many wire strippers not sure if I have made the best choice.
Any ideas, what are you using?
Thank you
Thomas
Monte
Germany
i had a manual wire stripper, then i tried a automatic one and never looked back....
CWP1616L
USA
I have an automatic wire stripper; it needs a lot of wire to grab onto so it can make the strip. If you're in a situation where you have to make a strip on a short piece of wire, the manual strippers with the dies in the front are the way to go.
frankush
IL
I use wire strippers every day and I've never liked the automatic ones. I use the Klein version of the Craftsman in the picture above.
CWP1616L
USA
Believe it or not, I got the Klein version too. From my experience, the Kleins don't bite into the insulation far enough on multi-strand wires. If I'm stripping a 14AWG wire, I have to first bite into the insulation with the 16AWG die and then switch to the 14AWG die to pull the insulation off. However, for solid strand wires, the Kleins work excellent.
Rezeppa
Newport, MI
I hate automatic wire strippers and I have used a lot of them. I have a set of Matco that have sat unused for at least a year I actually use my snapon PWCS7 for almost all of my wire stripping needs. Sometimes I use it as a wire stripper and use I different tool to crimp idk why I like it so much but I think it is just the sharpest or has the tightest tolerances but I have found it hands down to be the fastest for me at least.
vhol5
West Texas
I use these all day long. I have had them for at least 10 years. I used them for about 8 of those years 6 days a week 10+ hours a day and they still work great. They are like 18 bucks and worth every penny.
What are "these"?
AV tinker er
SoCal
I use the automatic strippers on an almost daily basis. When it comes to the automatic ones the “dies” are what make the difference. Most of the time the dies are not correct for the type of wiring that is being stripped. As an example on the aircraft we have Kapton coated wiring and Teflon coated, using the strippers that have dies designed for Teflon will not effectively stripe Kapton wiring (even though both are “X” gauge). If you have the correct die they are fantastic, they do not put as much stress on the wire as other types of strippers do, and for me at least, they do not knick the wire as much.
That being said check out Ideal Strippers, I like these.
lbgradwell
Oakville, ON
As always, there are many different opinions on this...
I will also side with the automatic strippers, although, as noted, the Ideal/Speedex style do require a lot of wire. Having said that, they are still the style I prefer if the above objection is not an issue.
If the amount of wire is an issue, you will benefit by owning an end-stripping style like the manual Knipex or automatic Weidmüller. (The Weidmüllers pictured above are from the late 1980s and are new to me; they seem to work very well and newer versions claim to offer "improvements")
I still have the pressed steel type too as they can be useful for cutting off and re-threading bolts in addition to stripping wire and crimping connectors...
Jsf721
LI, NY
I just purchased a set from HF to fix a break in the alarm wire that I cut doing dry wall work. Worked like a charm and looks like my Craftsman what got totalled in a recent hurricane flood.
Monte
Germany
<iframe width="560" height="315" src="http://www.youtube.com/embed/12avtPzXky8" frameborder="0" allowfullscreen></iframe>
<iframe width="560" height="315" src="http://www.youtube.com/embed/LOiCEeJQ24g" frameborder="0" allowfullscreen></iframe>
<iframe width="560" height="315" src="http://www.youtube.com/embed/0RXf_m0G9qg" frameborder="0" allowfullscreen></iframe>
lbgradwell
Oakville, ON
Monte, do you know if all these German companies truly independently manufacture these suspiciously-similar strippers or is there a common OEM?
nanofrog
I'd suspect many are rebranded (seen Weidmuller models under other names).
One example that turns up under multiple names, and is an excellent model, is a Pressmaster Embla. Swedish made though, not German. These turn up under Wiha, Xcelite, Greenlee, and a few others.
One thing I really like about them, is there are different cartridges for them for different types of wire (3x; PVC, Teflon, large gauge & easily identified by color).
Mr_fixit
Rustylvania
NEWARK is overpriced.
I like the Ideal, I've been using some of the same ones for 20+ years. And bough a few more, for different wiire sizes. On newark they're about 45 bucks, In local stores they're about 25 bucks.
rshadd
Doylestown, PA
I have a few different sytles.
Some autos...
This is what a grab most of the time though...
One of these days I'll break down and buy the Snap-on PWCS7.
Monte
Germany
lbgradwell
Oakville, ON
