Can anyone ID this wood type?
TT_Vert
Wauconda, IL.
I have a stair post that I need to get a handrail for up the wall per code and I want to have the hand rail be the same wood so the stain color will look this same. Do any of you have any idea what kind of wood this is? I got it at Home depot but they have this in like 4 or 5 different wood types.
Thanks
Dave
Kaizen
New England
Put up a close up pic of the thick part of the posts. Looks stained from far away
T
TT_Vert
Wauconda, IL.
Sorry, I thought it would let you zoom in.
Is this any better?
engineer2
Chicago burbs
Around here, there is a 95% chance it is oak. Need a closeup showing the grain. Looks to be pickled oak stain, which was popular in the 90's. You may have to try a few different brands on a test piece to get it right.
PNWguy
Near Grants Pass, OR
Could be maple, because it's so light. However, pickled oak was much cheaper and popular.
I doubt you'll get a perfect match, but I'd buy some extra material and a few small cans of stain.
Reason #2476 why I love oil finishes that don't change the color of the wood.
dfiler2
NW Minnesota
I would also say maple, but could be many light grained woods, almost sure it's not oak. Oak has an open pore structure and that is too smooth. A real closeup would help.
K'ledgeBldr
Johns Creek, GA
wrenchguy
NW Indiana
lj smith make parts in all above species mentioned above. looks pickled finished so i'd have to Einstein the grain closeup.
T
TT_Vert
Wauconda, IL.
Guys I should be a bit more clear. This all was purchased from HD and this is prior to finishing a few years ago. Now I am having to add a handrail up higher so I want to try to match that wood to what i have no so when I stain it matches my existing posts. Could it be poplar? I see HD sells this post in poplar, red oak and hemlock and it looks similar in shade and sheen to the poplar on their site.
This is the after staining of this. Sorry for bad pic but it's all I have.
Post I think I may have
T
TT_Vert
Wauconda, IL.
The wood was most certainly unfinished. We stained it. Seems like the oak is a bit more red than what I have.
fasteddie
Poplar usually has green streaks running through it and is usually considered a paint grade. Maple would probably be the most expensive option, is it likely you would have gone for the big bucks when you bought it? My guess is red oak but without a real closeup of the grain, it's impossible to tell. If the grain is somewhat rough and bumpy, it is most likely oak.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Red oak. The grain pops out with the darker stain on it. Remember, red oak is light colored and white oak is darker colored.
If you still have stain left, go get yourself a piece of red oak and stain it to see if it matches. If it does, you're good to go.
PugetDude
Superstition Mountains, AZ
The trim is definitely red oak.
Lynden
Southern California
Have you checked your Home Depot account? Mine goes back 9 years and gives a product description, model number and store SKU for all of my purchases.
CJ7VFR
Central New Jersey
This is very true.
I had to add a small section of hand rail going up to my second floor just like the OP is doing at his home. My stairs are set up a lot like his.
I tried to find a wood rail that was close to the one that was already there, and I ended up going with a red oak rail.
Below are two pictures of the portion of the hand rail I made before I stained it. As you can see it is quite light colored before you apply any stain. And the grain is hard to see until the stain is applied as well.
I added a few pictures of what it looked like when I was done staining it and applied a few coats of polyurethane to it. My cat Sarge was there to help out, and in the last picture he is going to get me a beer!!
Jim
Dzlpete
Williamstown, MA
Oak would certainly be a standard specie stocked by home depot, but maple is unlikely. Maple is typically a higher end "order only" product.
So, Beech is a standard product offering and would fit that picture, though the pics are not nearly good enough for positive ID.
ford33
Chicago, IL. USA
This rail was likely stained so color is not a good wood family selection criteria. You are looking to match the grain of the wood and hardness.
Take a piece of the rail to a Rockler, Home Depot, Lowe's or other wood store and find a similar grain pattern regardless of the wood type. Buy several pieces to make sample color coupons. Then find a few small cans of stain that are close to the finished color. Mix the stain in small quantities until the colors are a close match. Then mix a larger batch and try it in different sunlight and lamp lighting to find the best match. Then stain the new railing.
I just noticed you are in the Chicago area. Go to Owl Lumber and see if they have the stair parts you need. They have a huge selection of rail and trim in many wood varieties for homes.
