48windsor
I have a GFI by a man door which means there is Romax running to it . My question I guess is ; Is if permittable to cut romax before the GFI to put in an outlet than continue onto the GFI outlet.
Its okay. If the added outlet is in the garage then it too needs to be GFI protected. You can swap the receptacles making the new one a GFI and have it also supply GFI protection to the down stream outlet.
Shouldn't the first outlet on the circuit be a GFCI outlet and not a GFI outlet?
I'm getting confused.
A ground fault interrupter (GFI) outlet only protects that outset. It does not protect any downstream outlets. Right?
A ground fault circuit interrupter (GFCI) outlet protects the GFCI outlet and all the outlets downstream. Right?
