Even the high percentage ethyl rubbing alcohol (70%) is 30% water.
It won't burn.
But HEET or other "de-icers" are a different story.
I wpuld worry about drying out or desolving seals first.
An air pressure style spray gun would be the best.
Section 5: Fire and Explosion Data
Flammability of the Product:
Flammable.
Auto-Ignition Temperature:
The lowest known value is 399°C (750.2°F) (Isopropyl alcohol).
Flash Points:
CLOSED CUP: 18.3°C (64.9°F) - 24 deg. C (75 deg. F)
Flammable Limits:
The greatest known range is LOWER: 2% UPPER: 12.7% (Isopropyl alcohol)
Products of Combustion:
These products are carbon oxides (CO, CO2).
Fire Hazards in Presence of Various Substances:
Highly flammable in presence of open flames and sparks, of heat. Flammable in presence of oxidizing materials. Non-
flammable in presence of shocks
Explosion Hazards in Presence of Various Substances:
Slightly explosive in presence of open flames and sparks, of heat. Non-explosive in presence of shocks.
Fire Fighting Media and Instructions:
Flammable liquid, soluble or dispersed in water. SMALL FIRE: Use DRY chemical powder. LARGE FIRE: Use alcohol foam,
water spray or fog.
Special Remarks on Fire Hazards:
Vapor may travel considerable distance to source of ignition and flash back. CAUTION: MAY BURN WITH NEAR INVISIBLE
FLAME. Hydrogen peroxide sharply reduces the autoignition temperature of Isopropyl alcohol. After a delay, Isopropyl
alcohol ignites on contact with dioxgenyl tetrafluorborate, chromium trioxide, and potassium tert-butoxide. When heated to
decomposition it emits acrid smoke and fumes. (Isopropyl alcohol)
Special Remarks on Explosion Hazards:
Secondary alcohols are readily autooxidized in contact with oxygen or air, forming ketones and hydrogen peroxide. It can
become potentially explosive. It reacts with oxygen to form dangerously unstable peroxides which can concentrate and
explode during distillation or evaporation. The presence of 2-butanone increases the reaction rate for peroxide formation.
Explosive in the form of vapor when exposed to heat or flame. May form explosive mixtures with air. Isopropyl alcohol +
